Old 07-06-2016, 04:25 PM   #776
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
And here is after, I need to get a better buffing wheel for my drill or Dremel so I can finish the rest of the firewall
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 07-07-2016, 05:38 AM   #777
CURSED GEARS
That looks pretty nice. When I built my hotrod 39 Chevy Truck, I buffed out the firewall one evening and it came out great! Had to many holes in the firewall that I didn't need, and ended up welding them all shut, which ruined the paint. I ended up painting it. You keeping the paint, or using new? I enjoy watching this.
CURSED GEARS is offline   Reply With Quote
Old 07-07-2016, 01:52 PM   #778
62stepside longbox
Thanks man, I think I'm going to preserve the paint on the firewall since it has the original chalk markings on it and the paint isn't bad. The rest of the truck However will be repainted the same colour as the firewall
Old 07-07-2016, 09:30 PM   #779
You did good on that firewall!
Old 07-08-2016, 04:11 AM   #780
62stepside longbox
Thanks bill, it sure does look good. It'll look even better when it matches the rest of the truck when it gets painted
Old 07-08-2016, 04:17 AM   #781
62stepside longbox
Wink Re: A 15 year old's project. Rusty 62 stepside
Been spending the past two days cleaning and painting the engine. First I sraped just over 3 lbs of dirt and grease of the engine then I wire-wheeled it and then gave it a wash. The original colour for the 261 is actually almost the same as John Deere green so I used some tractor and implement paint, it's real tough stuff, oil and gas proof and high temp resistant.
Old 07-08-2016, 04:18 AM   #782
62stepside longbox
02
Old 07-08-2016, 07:04 AM   #783
I like that green
Old 07-08-2016, 09:56 AM   #784
60chevyjim
60chevyjim's Avatar
nice job on the engine . now it will look great when you put it back in .
60chevyjim is offline   Reply With Quote
Old 07-08-2016, 11:59 AM   #785
AJCK87
Sweet! Engine looks awesome man
AJCK87 is offline   Reply With Quote
Old 07-08-2016, 12:37 PM   #786
62stepside longbox
I like that green
Thanks bill, so do I!
Thanks Jim, yep it definitely will look much better than the old pile of dirt and grease it used to be.
Thanks Anthony, I'm planning putting quite a few coats on so if something spills on it I can just wipe it right off. Once the painting is done I'm going to do some pin striping and decals on it
Old 07-08-2016, 03:37 PM   #787
Grizz1963
Grizz1963's Avatar
I like it a lot.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-13-2016, 08:52 PM   #788
62stepside longbox
Originally Posted by Grizz1963 View Post
I like it a lot.
Thanks rian, so do I. I'm painting some parts dark blue so it should go well with the green
Old 07-14-2016, 08:05 PM   #789
62stepside longbox
Have been working on engine paint and got lots more coats of green on. The cast iron is glossy smooth and if I get any grease on it I should be able to just wipe it off. I can see my reflection in some parts
Old 07-14-2016, 08:13 PM   #790
62stepside longbox
I detailed the "captains bars" and the ID number so they are easily visible. This is to prove all the old guys wrong at the carshows that say "it's probably not a 261 and if it is it's not original to your truck". Now I'll be able to prove them wrong
Old 07-14-2016, 08:14 PM   #791
62stepside longbox
And added some more blue in there on the side cover
Old 07-14-2016, 08:16 PM   #792
62stepside longbox
I also used the blue for some stripes on the valve cover.
Old 07-14-2016, 08:32 PM   #793
BFoley
BFoley's Avatar
Very cool engine colors. Did you prime it first or just shoot it with implement paint?
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 07-15-2016, 12:21 PM   #794
66ChevyMax
66ChevyMax's Avatar
Nice job on the engine
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 07-15-2016, 03:13 PM   #795
62stepside longbox
Thanks Ben, I made sure it was super clean and shot it with the implement paint. I've probably done about 10 coats by now.
Thanks Craig
Old 07-15-2016, 09:09 PM   #796
TJ's Chevy
TJ's Chevy's Avatar
Looks great buddy! Reminds me of painting my engines. Always the funnest part imop.
Old 07-16-2016, 01:17 AM   #797
62stepside longbox
Thank tj. yep painting the engine sure is fun, makes everything look so pretty
Old 07-19-2016, 02:29 AM   #798
62stepside longbox
Drove 4hrs down to Vancouver today to pick up my 60 gmc hood I bought a few months back. It's actually really straight other than one good sized ding and there's also one small rust spot. I'll get back home on the weekend and then I'll start to do some metalwork on it and probably sell the old hood
Old 07-19-2016, 11:55 PM   #799
62stepside longbox
Came home earlier than expected due to bad weather. The hood is now home, I've been waiting for months and I finally have it here
Old 07-23-2016, 01:59 AM   #800
namloc
namloc's Avatar
lookin good . Got the hood finally .That is going to change the look for sure.
The Snortin' Bull
namloc is offline   Reply With Quote
