Closed Thread
Old 07-02-2016, 02:45 PM   #2401
chevy2tom
chevy2tom's Avatar
Re: What did you do to your truck today part III
Bought more parts
chevy2tom is offline
Old 07-02-2016, 05:21 PM   #2402
Classic v6 GMC's
Classic v6 GMC's's Avatar
Blasted and painted the rear tow hooks for 3/4 ton 4x4. Now we just have to restore the truck.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline
Old 07-04-2016, 11:26 PM   #2403
Praxiss454
Praxiss454's Avatar
Today I installed a new manual fuel pump. Old one's diaphragm was shot. Tomorrow she gets a re-manufactured carb.
Praxiss454 is offline
Old 07-07-2016, 11:34 PM   #2404
Backpayne
Installed a front sway bar from a '78 1 ton using Energy poly bushings and CPP sway bar mounts. Unfortunately I haven't had a chance to drive it, yet. It was time for Big Brother!
Backpayne is offline
Old 07-08-2016, 12:49 AM   #2405
goatless
goatless's Avatar
Installed peep mirrors, driver and passenger (convex). Should have purchased convex for both sides.
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline
Old 07-08-2016, 07:43 PM   #2406
Jimal
Jimal's Avatar
https://www.youtube.com/watch?v=1u3UCa-qgSE
Replaced the Raptor mufflers that came on the truck with a set of Thrush welded mufflers. Sound was a reason, but the big thing was I wanted the outlets to be symmetrical and I couldn't get a new Raptor to match the old one.
Jimal is offline
Old 07-08-2016, 07:59 PM   #2407
chevy2tom
chevy2tom's Avatar
Found a chrome bumper under the white paint & my grill is painted aluminum so that's next to be stripped
Old 07-08-2016, 08:33 PM   #2408
badriand
badriand's Avatar
Been 2 years since i touched. Charged battery this week and backed outta garage and started on roof and hood again.
badriand is offline
Old 07-08-2016, 09:10 PM   #2409
Backpayne
Finally drove it on the very curvey roads around here ansd the sway bar makes a huge difference. I don't have to hold on to the door to keep from sliding over anymore! Woo hoo!
Old 07-08-2016, 09:27 PM   #2410
chevy2tom
chevy2tom's Avatar
Any pics of the seat bar install BP?
Old 07-08-2016, 10:57 PM   #2411
Backpayne
I ran out and took a couple of pictures. Disregard the excessive grease and the white lithium grease (stupid creaking spring).
Old 07-09-2016, 09:53 PM   #2412
oliver63
oliver63's Avatar
5 speedName:  20160621_085821.jpg
1990 Silverado Sport
2010 Silverado K1500
1996 K2500
oliver63 is offline
Old 07-09-2016, 10:53 PM   #2413
LDO
LDO's Avatar
Originally Posted by oliver63 View Post
interested in this setup. More info?
LDO is offline
Old 07-10-2016, 02:15 AM   #2414
Dsuper5
Dsuper5's Avatar
I need a 5 Speed real bad! Running 3200 rpms 70mls/hr 4;10 and 35s with the old 3speed granny no fun!
Its fun in the dirt or on the Rocks.... but its pavement to get there!
Dsuper5 is offline
Old 07-10-2016, 11:53 AM   #2415
oliver63
oliver63's Avatar
It is a Tremec TKO 500 5 speed. Silver Sport Transmission moved the shifter location to the top of the transmission when I ordered it. It was a fairly simple job. The transmission fit the floor of the truck except the bolt in section. I raised the back of the bolt in section 2 inches. My being a '63 I used the e-brake crossmember for the transmission crossmember and left the bell housing mounts off. A longer speedometer cable and shorten the driveshaft. Your bell housing needs the correct size hole for the transmission. Name:  20160621_173628.jpg
1996 K2500
oliver63 is offline
Old 07-10-2016, 01:12 PM   #2416
LVPhotos
LVPhotos's Avatar
I used my factory 3 on tree housing for both t5 and TKO 600. I went to the hydraulic bearing with new headers because fork didn't clear them. I was able to rotate the shifter into #2 position with the Porterbuilt stuff moving things forward and up. Also could put a Gear Vendor od and make a 6 speed over/under drive for about same $.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 07-10-2016, 04:34 PM   #2417
LDO
LDO's Avatar
Is elevating the high hump necessary? Reason I ask is because my 66 was a 4 speed with a low hump which the PO butchered up cutting the hole for the shifter so I cut all that out and installed a high hump with the matching firewall section.
Am I going to have to raise the high hump as well? SBC with a TKO 5 speed.
thanks.
LDO is offline
Old 07-10-2016, 04:53 PM   #2418
oliver63
oliver63's Avatar
thanks.
With the high hump you won't need to change anything about the floor. I think the '66 e-brake is different from my '63...I had to redo my e-brake.
1996 K2500
oliver63 is offline
Old 07-10-2016, 06:13 PM   #2419
steveb64
steveb64's Avatar
Spent the afternoon messing with the choke and timing, trying to get the Cadillac 500 to start better when hot.
steveb64 is offline
Old 07-10-2016, 07:23 PM   #2420
sags
Finally got the new motor in, vacuum timed and adjusted carb. Got the transmission out of gear. Teed the vaccuum line. Couldn't wait to drive it so I took it to the monthly cruise night with my daughter.
sags is offline
Old 07-10-2016, 07:39 PM   #2421
jtrichard
It is a Tremec TKO 500 5 speed. Silver Sport Transmission moved the shifter location to the top of the transmission when I ordered it. It was a fairly simple job. The transmission fit the floor of the truck except the bolt in section. I raised the back of the bolt in section 2 inches. My being a '63 I used the e-brake crossmember for the transmission crossmember and left the bell housing mounts off. A longer speedometer cable and shorten the driveshaft. Your bell housing needs the correct size hole for the transmission. Attachment 1551139
So you now have a MID hump cool
jtrichard is offline
Old 07-10-2016, 08:07 PM   #2422
vin63
It's Better With Nitro
vin63's Avatar
Mocked up my tank and bottles today after getting parts back from coating and paint...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 07-10-2016, 10:26 PM   #2423
maydaymike
maydaymike's Avatar
Finished painting the front and left side of my engine, and put it back together with all new belts and hoses and gaskets. Still have the oil pan to do yet. Please excuse the overspray on the mounts. When I jack up the engine to do the oil pan, I intent to remove the towers, repaint and install with new mounts.
maydaymike is offline
Old 07-11-2016, 04:15 PM   #2424
oliver63
oliver63's Avatar
Four wheel disc brakes...Name:  20160707_103942.jpg
1996 K2500
oliver63 is offline
Old 07-15-2016, 11:41 AM   #2425
forestb
forestb's Avatar
I went and looked at it at the painters. I should have it back by the end of next week.
forestb is offline
Closed Thread
