Innie and Outie ? Or are they all the same ?
Are each of the trailing arms for our trucks made up of an Inner half and Outer half or are both identical ? Switch the drivers-side arm with the passengers-side and nobody would be able to tell (except for the brake-cable bracket) ?
Or maybe a better way to ask is; are the bushing bores identical from left half to right half on same arm ? Can you put bushings in from either direction ? I ask because I split my arms apart years ago and can't find my bushings at the moment but could've sworn they were stepped and would only go in one way, and yet I have 4 arm-halves all with the same size bores ... |
#2 | |
The Older Generation
Re: Innie and Outie ? Or are they all the same ?
Without the cable bracket they are identical. LockDoc
After reading your original post again I think I need to clarify my response. In your first sentence you ask: "Are each of the trailing arms for our trucks made up of an Inner half and Outer half or are both identical?" There is actually a right half and a left half to each trailing arm (because of the angle in front of the U-bolt holes, but the trailing arms, side to side are identical without the cable bracket. LockDoc
My reason for asking is mostly to do with the bushings actually, and to clarify why I'm asking is because I'm thinking I have 4 'inner' halves, 2-from my truck (my avatar pic) and the other 2 from a parts truck I had way back when.
I think (not 100% sure but) I maybe tossed all 4 'outer' halves (the 2 outers from each truck that were more beat-up than the 2 inners from each truck). All 4 halves I have (now/in my shop) are identical, including the bores for the bushings, including the rivet holes, so if I put them back together am I gonna find that I can't get the bushings in ? I had an idea in my head that the one half (of each complete/assembled) arm had a larger diameter bore than it's partner-half did, so you could only put the bushing in in one direction. If the bushings are one diameter throughout (not stepped) then it wouldn't matter if I do have 4 'inners' ? And I've just made 2 good arms out of 2 sets of arms using only the remaining 'good' (inner) halves ... Yeah it's an unnecessarily complicated question I wouldn't have to ask if I could just find my original bushings (or wait til I buy replacements), just don't want to spend a bunch of time welding up (the 4 pieces) my 'new' arms to find out the bushings won't fit. |
![]() Join Date: May 2014
The bushings can be pressed in from either direction. They're the same size on both ends. I purchased new bushings last year from my local Chevy dealer since they still produce them. It was cheaper than paying for shipping from an online vendor. If you get poly bushings you need the original shells because they don't come with them. I can post a part # if you'd like. I have the receipt in my C10 file at home.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
Whewwww ! Good to know !
Yeah, I have a buddy at a local dealership so a part # would be awesome. |
#7 | |
The bushings are the least of your worries.... You can't put 4 inners together to make 2 arms. Easy thing to do is to get the pieces out and try putting them together. Not going to work.... LockDoc
#8 | |
If the bushing bores are the same on both halves (which is what I was asking), and so GM only stamped a 'left' and a 'right' half (and not 4-different pieces) then it's all good. Yeah I wasn't thinking I could combine 4 'lefts' ... LOL |
3762012 and they're sold individually.
