Old 07-08-2016, 08:50 AM   #1
ohboy321
ohboy321's Avatar
Help ID K10 Steering Gear - 67 or later?
I have a 67 K10 with power steering, and I want to replace the steering gear. Although my VIN and cab are 67, I am not sure about the rest of the truck.
Someone in another thread mentioned that the 67 K10 did NOT have a dimple in the frame near the steering gear.
Can someone help me ID the steering gear/frame from the picture below? If it is not a 67 gear all the better, as I do not see anyone listing refurbished units for that year. Plenty available for 68-72 though.
Thanks for the help.
-Steve
ohboy321 is offline   Reply With Quote
Old 07-08-2016, 10:58 AM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: Help ID K10 Steering Gear - 67 or later?
I don't have a definitive answer for you, but your frame looks to be a 69 or newer. The radiator mounting bracket / spring mount are different on the 67-68 frames. If you look on top of the frame rail near the steering box there should be a number stamped into the frame. This is the vin # and if original to the truck it would match or partially match the vin of the body.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 07-08-2016, 11:06 AM   #3
CUSTOM/10
CUSTOM/10's Avatar
This might help you determine what year your frame is, I also put a link to it if you can't read it.
http://www.lmctruck.com/icatalog/cb/t.aspx?Page=8
Gary
72 SWB 4x4
My 72 SWB Build
Old 07-08-2016, 07:14 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
67 4x4 didn't have that style steering gear. It had ram assist. That doesn't look like a 67 frame to me. I've been wrong in the past tho.
Tyler
57taskforce is online now   Reply With Quote
Old 07-08-2016, 07:58 PM   #5
ohboy321
ohboy321's Avatar
Thanks Gary, I didn't know about the numbers on the frame. I can't read the LMC decode info on this laptop (even with glasses), but with the number and a little poking around in the forum I discovered that it is a 1970 frame.
It has an open knuckle front axle with drum brakes, which makes sense now. This is a huge help when servicing the chassis items.
VIN/cab is 67, chassis is 70, 327 is 66. All my wife can think of is the Johnny Cash classic, "One Piece at a Time"
-Steve
Old 07-09-2016, 08:32 AM   #6
ohboy321
ohboy321's Avatar
With the replies so far I dug some more and from referencing the online Chassis Service Manuals see the difference between the 2 types.
I am glad I have the newer version, and have already ordered a replacement.
For reference, my frame number is 0Z161077. I read that as 1970 made at the Fremont plant.
-Steve
Old 07-09-2016, 02:07 PM   #7
Bigdav160
Bigdav160's Avatar
Hopefully someone with that VIN doesn't want his frame back.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-10-2016, 04:16 PM   #8
CUSTOM/10
CUSTOM/10's Avatar
Hey Steve,
Here in NH, as long as none of the part numbers /vin numbers show up as stolen you can get a new vin for an assembled vehicle. It would need to be inspected' and all numbers found recorded by a state trooper or possibly by a reg car dealer. Or if it was already reg or titled all that's needed is a bill of sale for a vehicle that old.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 07-10-2016, 07:45 PM   #9
ohboy321
ohboy321's Avatar
Hey Steve,
Gary
Garry, Lucky for me the previous owner had it registered in NH when I bought it, so I was able to register it the same day I brought it home. I may apply for a title at some point, just to have one for it.
While I wait for the rebuilt steering gear to be delivered, I adjusted the one I have to see if I could take some play out. It helped a little, but I will be glad to get the replacement installed.
-Steve
