#376 | |
Re: Post Pics of your Static Drops!!
In the front what is the first thing that makes contact so that it will not go any lower?
#377 |
forestb
the bump stops are the first thing that hits with no front springs in it. so I removed them now the lower a arms are sitting tight against the cross member. it has stock spindles on it and the cross member is about a inch or 2 off the ground now. in the back the stock un cut frame rails are laying on the rear axel housing . I need to pan cake the front cross member 2 inches and put C notches in the back so I can put some short springs in it to get some working suspension . its going to be a 6cyl 5spd . Last edited by 60chevyjim; 03-09-2016 at 04:50 PM. |
#378 |
But Found Her 25yrs Later!
A sheet of diamond plate steel and tired springs in the back. Lowered torsion bars in the front.
#379 | |
That is interesting I figured that the cross member hitting the ground would be the first thing to bottom out (excluding the bump stops of course). Would using tubular lower A-arms keep them from bottoming out first and allow you to go lower so that the front cross member makes contact with the ground?
#380 |
Before & afters. 5.5"-7" drop. Front is '83 Suburban k-member with 2.5" drop spindles & 3" drop springs. Rear is 5" drop springs, made my own drop plates for another 2", c-notched frame. Rims are 18x8, 245/45/R18 front, 255/55/R18 rear.
#381 |
Update. lowered my truck up front 2" more. 4/6 drop now.
Stovebolt-It is painted |
#382 |
mines in the shop now, getting CCP grand slam skit 5/6 drop and brakes on 6 bolt rotors. putting white GM transport wheels on it.....
I will post more when its done. |
#383 |
2" drop springs in front. One round cut out.
4" rear springs. 22" wheels |
#384 |
Front Belltech 2 1/2 spindles and 3" coils / 4" coils and 2" blocks out back
#385 |
CPP 2.5" drop spindles with 3" springs in front and 5" Springs with 2" blocks out back. Tires are 275/50 I think all around but switching to a 255/60 or so in the front. So that should bring it down a tiny bit more.
#386 |
C10 addict
Do you have any rubbing issues in the front when turning?
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
#387 |
#388 |
#389 |
I'm just glad to be here!
Bumwine - love the look of your '65!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#390 |
#391 |
4.5 / 5 drop , 5 inch coils in the rear 2 inch coils and 2.5 drop spindles in the front
#392 | |
1957 Chevy swb 1964 Chevy swb panel |
#393 |
Transports are a 22" stealie/smoothy made by gm. They can be ordered with the same bolt pattern as the stock 15" wheels. Commonly used on vehicles that are "slammed".
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#394 |
FLOP hood in place finally!!!
#395 |
C-10 blue devil. '66, 6 cylinder.
Getting there.... |
#396 |
![]() Join Date: Aug 2014
Here is my 65 C10 5/7" drop. spindles, UCAs, springs, and rear blocks. Tires are P215/70R15 all around.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
#397 |
Zack - Nice truck. I dig that shop truck theme!
#398 |
Primed the hood this weekend. It was blue. 5"/7" CPP drop.
#399 | |
![]() Join Date: May 2014
How does it drive? Are you running a c-notch, shock relocator, flip kit, or anything of that nature?
Mike OIF 2003-2004 Veteran (US Army) I support the Wounded Warrior Project ![]() "Gotta work on the nut behind the wheel before you start fixing bolts on the car"– Author Unknown My 1965 Chevy C10 LWB build thread |
#400 |
Perfect!
84 GMC One ton 4x4 454 4 speed 62 Chevy C10 short fleet plus about 13 previous gm trucks from 1960 to 2000 |
