Old 07-09-2016, 05:27 PM   #1
718jwh
Rocker that fits
Putting on new rockers on my 72 I have a Key parts rocker but it does not fit that well (see picture) anyone know a brand that fits better
John
718jwh is offline   Reply With Quote
Old 07-09-2016, 05:39 PM   #2
Eddie H.
Eddie H.'s Avatar
Re: Rocker that fits
I used Tri Plus the last time I replaced rockers. They fit like OEM.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 07-09-2016, 08:40 PM   #3
FlameOut
I also used Tri-Plus. Fit great with no problems
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 07-09-2016, 09:06 PM   #4
swamp rat
swamp rat's Avatar
Mine was the same so i did a pie slice and grafted in some metal.. I think i had Key parts also.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-09-2016, 09:19 PM   #5
GR8-68
GR8-68's Avatar
Okay here is a comparison for you the rockoer with my two fingers on is a nos GM rocker for drivers side and the other is a key parts rocker for passenger side, comparing the two they really are not to far off. And someone correct me if I am wrong but I believe key is only a distributor not a manufacturer. On my label it says tri plus no. GM27006r
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-09-2016, 09:27 PM   #6
718jwh
Larry
So the NOS rocker you have has the same distance between the bend and weatherstrip lip like in my picture ?
I got the Key rocker from LMC if that's a tri plus hate to order another one with same issue
John
Old 07-09-2016, 09:35 PM   #7
GR8-68
GR8-68's Avatar
I will run out and measure real quick
Larry
"Project 68"
paypal.me/ldgrant
Old 07-09-2016, 09:37 PM   #8
GR8-68
GR8-68's Avatar
Label
Larry
"Project 68"
paypal.me/ldgrant
Old 07-09-2016, 09:42 PM   #9
718jwh
That looks like my label as well it says tri plus number wonder if that means it's made by tri plus or just referencing there number
The picture you sent looks like maybe there is more metal between bend and weatherstrip lip but hard to tell from back side
John
Old 07-09-2016, 09:43 PM   #10
GR8-68
GR8-68's Avatar
the measurements seem real close the biggest difference I would see and you can tell in my first pic is the radius's are a bit tighter on the nos rocker that may make the difference.
Larry
"Project 68"
paypal.me/ldgrant
Old 07-09-2016, 09:47 PM   #11
GR8-68
GR8-68's Avatar
I saved your pic to my computer so I could enlarge it to see the trouble area better, are you positive you have enough cutout of the old rocker ? Even enlarging it it is hard to tell. Do you already have it tacked in ?
Larry
"Project 68"
paypal.me/ldgrant
Old 07-09-2016, 09:53 PM   #12
718jwh
It's not tacked in yet, I removed old rocker completely it's all original metal above rocker in picture but like swamp rat said I will need to cut the area between the weatherstrip lip and first bend to move the weatherstrip lip to line up with pillar then weld in a piece I was hoping to find a better fitting rocker instead
John
Old 07-09-2016, 09:57 PM   #13
718jwh
Might be easier to see in this picture
Old 07-09-2016, 10:02 PM   #14
GR8-68
GR8-68's Avatar
For some reason that first 90 degree bend after the weather stripping lip looks real narrow compared to mine
Larry
"Project 68"
paypal.me/ldgrant
Old 07-09-2016, 10:04 PM   #15
718jwh
That's what I was thinking would you mind taking a picture of yours at about the same angle
John
Old 07-09-2016, 10:15 PM   #16
GR8-68
GR8-68's Avatar
I think it is their radius's that is making it not fit well. It is about a 1/2" right there. And the weatherstrip flange is also about a 1/2"
Larry
"Project 68"
paypal.me/ldgrant
Old 07-09-2016, 10:16 PM   #17
elf w/capital T
yeah that isn't fun and I used some wood and bent to fit lol
elf w/capital T is offline   Reply With Quote
Old 07-09-2016, 10:23 PM   #18
718jwh
Yeah that is it, thanks for your help Larry !! guess I am going to have to beat it in to submission.
John
Old 07-09-2016, 10:38 PM   #19
GR8-68
GR8-68's Avatar
The other thing I noticed compared to the nos one is the lip for the weather strip is to wide on the repro
Larry
"Project 68"
paypal.me/ldgrant
Old 07-09-2016, 10:40 PM   #20
projectking
projectking's Avatar
https://tabcoparts.com/pickup-trucks...1967-1972.html
Throw that one away and try one from them. I'm not trying to offend anyone but regardless of the screen size that thing is dead wrong.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 07-10-2016, 12:55 AM   #21
swamp rat
swamp rat's Avatar
I was also told that Tri-Plus and Key parts are the same, i often wondered if its possible the die press sometimes does not stamp all the way and as such does not form the bends properly? Factory reject passed on to someone? One dealer gets the crap at a discounted price?
I also had to clearance the Tri Plus inner rocker around the A pillar area. And both my Tabco and Tri Plus A pillars needed a lot of persuasion to get aligned.
I have seen and subscribed to a thread showing all the cab corners stacked on top of each other and it looked like the Tabco was the best, i'm still undecided on the outer rockers tho.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-10-2016, 02:19 AM   #22
Gmc.guy
Gmc.guy's Avatar
I use the same name parts a few times a year (rockers,cab corners, inner rockers) for the square body trucks 73+. There is a big difference in parts. I have had terrible parts that were short and exchange for another and its same as before but fitting perfect. I have done that a few times. If the 2 one is better I make it fit
-Cody
Gmc.guy is offline   Reply With Quote
Old 07-10-2016, 02:20 AM   #23
Gmc.guy
Gmc.guy's Avatar
^^ I mean semi major fails. Not simple tweaks and pulls
-Cody
Old 07-10-2016, 07:18 AM   #24
GR8-68
GR8-68's Avatar
Pretty good video from brotherstrucks.com
https://youtu.be/plkeMVRUcyI
Larry
"Project 68"
paypal.me/ldgrant
Old 07-10-2016, 09:10 AM   #25
718jwh
Going to order a Tabco rocker and see if it fits better I will let you know when I get it
Thanks everyone
John
