Old 03-25-2016, 05:09 PM   #1
Bocephus69
need to find a smaller steering wheel
my old 69 is a pleasure to drive, but i cannot get used to the large steering wheel. can someone point me in the direction of a steering wheel that is not so expensive? the cheaper the better. my c10 is no beauty queen, she's a work horse. i need functional and cheep!
69 C10 fleetside long bed - 6.0/4l80E in progress
Bocephus69 is offline   Reply With Quote
Old 03-25-2016, 05:24 PM   #2
Ironhorse
Ironhorse's Avatar
Re: need to find a smaller steering wheel
I use a steering wheel from a late 80's Chevy truck which will mount to the truck column shaft with no problem. Horn was not much of a problem to hook up. Not sure I have pics that will show it, think it is a 16'' diameter. A bit smaller than stock. Go to small with no power steering and then you wind up with "Arm Strong Power Steering"
Best pic I have of it which doesn't show really well. Lots of options tho as most any GM steering wheel from early 60's to late/mid 90's will work as long as it is not air bag equipped.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 03-25-2016, 06:24 PM   #3
FirstOwner69
FirstOwner69's Avatar
Below is a leather wrapped wheel from a 94 S10 Blazer LT. There were several variations on this style wheel used through 1994. The Blazer LTs are the only models where I've seen the leather wrapped version. The second picture shows my original (for comparison), the LT wheel (top right), and 2 other versions of the LT style w/o leather. You do have to run a wire for the horn contact. Very simple to do.
I paid $20 for the leather wheel at the junkyard.
FirstOwner69 is offline   Reply With Quote
Old 03-25-2016, 10:07 PM   #4
Z10
Z10's Avatar
Here's one I picked up on eBay. New with kit around $130
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 03-26-2016, 07:53 AM   #5
Katrina/10
Katrina/10's Avatar
I have one of those wheels too, and I think they are great. Came off an early 90s full size pickup. You can still find them at salvage yards pretty cheap.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 03-26-2016, 04:02 PM   #6
poway
Z10: I have the exact steering wheel that I purchased on Ebay for my Chevy truck. I don't remember the seller's name. I decided to use it in my GMC. The problem is that I don’t have the GMC horn button. Do you have the link to the Ebay seller so I can order one? I’ve looked on Ebay and can’t find the GMC horn button. Thanks in advance for your help…Poway.
poway is offline   Reply With Quote
Old 03-26-2016, 05:53 PM   #7
Bocephus69
do those OEM 90s GM units "dish" the steering wheel back towards the driver? i dont want it any closer to me than the original steering wheel.
also, i see sellers are pretty proud of those on ebay.
Old 03-26-2016, 09:17 PM   #8
Z10
Z10's Avatar
Here you go. http://www.ebay.com/itm/4X-56-5mm-Ca...ZW1Be~&vxp=mtr
They stick on top of the factory Chevy emblem and cover it completely. But you are now sworn to secrecy about this little trick.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 04-12-2016, 11:36 PM   #9
67L30WGN
67L30WGN's Avatar
I just installed a 15" GT Performance model #36-5459 GT Retro Dark Wood steering wheel with their #11-1002 GT3 Std Chevy Bowtie horn. 4" Backset combined with their hub puts the steering wheel at about the same position as the original. It's a very comfortable steering wheel.
1972 Cheyenne Super 10 LWB
1965 Nova SS Evening Orchid
1967 Nova Wagon Factory Disc (1 of 565), 327/PG
1964 Ford Fairlane 500 HT
1962 Nash Metropolitan Convertible (Wife's car)
67L30WGN is offline   Reply With Quote
Old 04-13-2016, 09:12 AM   #10
halfstep
I agree the factory wheel is a bit big, especially with limited seat adjustment - tilt columns do help here.
I have these two factory wheels available. The three spoke is 14.5" wide and the two spoke is 15.5" wide.
$45 shipped ($25 for shipping!!!)
If you go to junkyard, know you will likely need a wheel puller with fine thread bolts.
halfstep is offline   Reply With Quote
Old 04-13-2016, 01:19 PM   #11
OUbesto
OUbesto's Avatar
I want to change my wheel, is there a certain type of "wheel puller" needed? An ebay link to the item would be great... thanks!
1970 C-10 CST, LWB, 402/400, A/C
OUbesto is offline   Reply With Quote
Old 04-13-2016, 04:39 PM   #12
custom10nut
custom10nut's Avatar
I had a Four Spoke 11 inch wheel (Out of my old Hot Rod) in mine fore a while. It was fine for running around and such, but I noticed it was more effort to drive on long drives. I ended up putting the Grant Wheel in that looks like the old Corvette wheel (and they come in Walnut, if you like that). Its not as big as the stock, but enough to make driving nice. For the puller, you can just go to one of the Autoparts stores and borrow a one for a deposit, you just have to take it back when you're done
custom10nut is offline   Reply With Quote
Old 04-13-2016, 04:47 PM   #13
OUbesto
OUbesto's Avatar
Thanks for the auto parts store loaner idea. I forgot that they have a certain number of tools.
Old 04-13-2016, 07:43 PM   #14
57larry
take a walk thru a junkyard with a puller. you'll find something. good luck
57larry is offline   Reply With Quote
Old 07-13-2016, 04:30 PM   #15
GTCS
GTCS's Avatar
If you have woodgrain in your cab another option is to use a '77 Caprice steering wheel. It is one of the few that say, "Chevrolet" on them. The earlier ones have, "Classic", which is kind of cool, too.
GTCS is offline   Reply With Quote
Old 07-13-2016, 08:16 PM   #16
Bocephus69
i did find one guys. i found one off of a cavalier. it is nice and small, just like i wanted. it doesnt look as nice as some of other options, but my c10 is a work truck, no beauty queen. so the cavalier steering wheel will do just fine!
