Old 03-15-2004, 02:32 AM   #1
Broken_down?
Unhappy not my weekend...
So this weekend on the way home from Susanville CA, about 10 miles form my house on the backroad called " Cherokee" road. Anyone that lives near here knows that taking a truck like these is rissky business.. a 2 lane road, and my truck takes my lane + half the other one..lol beatiful drive but a huge drop into the canyon if you screw up. Anyhow upto the top coming down I look at my temp gauge and it is running half way. so I found a place in some guys driveway to pull over and look and the altinator is wobbling. I shut her down and noticed the bottom bolt had come loose. no biggie. Untill I looked close and found my bolt had snapped off. now my water pump and altinator in not pumping. SO afetr fiddling round I got it to work with the belt loose but enough to turn the pump and alt. so I have to drill the bolt out of the head. And re-tap the bolt hole. what size is the alt bolt for a 71 350 SB? but none the less my baby got us home. gotta love these trucks!!
rich
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 03-15-2004, 02:52 AM   #2
cduster
Can't you use an easy-out? Might be easier than drilling and re-tapping. I believe the alt bolt is a 3/8 bolt.
Dan
cduster is offline   Reply With Quote
Old 03-15-2004, 03:07 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
When this happened to me, I was able to use a small flat head screwdriver and a hammer to just tap it out.
But that bolt hadn't been in there very long either, so it came out rather easily.
Old 03-15-2004, 03:19 AM   #4
Broken_down?
easy out? how does this work? is it expensive??
Old 03-15-2004, 03:26 AM   #5
cduster
Drill a smaller hole in the bolt, and pound the easyout in and turn the bolt out. Not too expensive. Dan
Old 03-15-2004, 07:08 AM   #6
OhioDan
OhioDan's Avatar
I always try and use a left handed (no BS) drill bit to drill the hole. That way, if you get lucky, it'll catch and back the bolt right out. No EZ out. If it doesn't, you've still got your hole drilled and can now use an EZ out. Just my $ .02 . Hope this works for ya?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 03-15-2004, 08:45 AM   #7
Bowtie67
Bowtie67's Avatar
Post
I have used an old bolt and superglued it to the broken bolt and sometiimes that works.
Bowtie67 is offline   Reply With Quote
Old 03-15-2004, 09:00 AM   #8
vtblazer
vtblazer's Avatar
Broken bolt
I've had good luck with a dremmel.
Use a cutting wheel and grind a slot in the bolt end that fits a standard screw driver, then just unscrew it.
vtblazer is offline   Reply With Quote
Old 03-15-2004, 09:59 AM   #9
Blue Beard
Blue Beard's Avatar
OhioCan, a machinist friend introduced me to the LH drill bits..didn't know there was such a thing...
Another way to remove broken bolts.
Go to your local welding shop and get some of the rod they use.
You put a nut over the broken stud and weld through the hole from the stud out to the top of the nut. The special flux core doesn't mess up the thread but allows you to put a wrench on it to remove.
Also is a punch available that bites into the edge of the screw to aid in removal.
all depends on how far down its broken and how tight.
Good Luck..
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-15-2004, 10:35 AM   #10
FirstGen
Just Don't Stop!
FirstGen's Avatar
Sorry but that just really cracked me up!
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
