Old 07-14-2016, 08:57 AM   #1
The1960APE
The1960APE's Avatar
1961 Tire to fender clearence...?
After some helpful posts from you guys we have decided to mini tub the 61 project. I already bought brand new wheel vintiiques 16x8 steelies and brand new tires, looks as if I jumped the gun.
Now I am thinking about jumping up to 18" or 20" wheels, possibly Mobsteel (Detroit steel) the plan for the rear is a 11" or 12" wide wheel and a 8" wide for the front.
My question for you guys is at what point will I run into issues clearing the front inner fenders?
The1960APE is offline   Reply With Quote
Old 07-14-2016, 09:50 AM   #2
LVPhotos
LVPhotos's Avatar
Re: 1961 Tire to fender clearence...?
8 3/4 at bumper leaves about 3 inches tire to inner fender. There are lots of pictures on my build thread with measurements.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-14-2016, 10:07 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Depending on how low your ride height will be, I found that a 28.5" tall, or taller, front tire rubs the top of the inner fender on my truck at ride height.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-14-2016, 01:05 PM   #4
The1960APE
The1960APE's Avatar
Thanks guys!
Vin63, I am running 2-1/2 drop spindles and have cranked the bars down some, I do not think I am as low as you are and I am looking at a 27.72 tall tire, so it sounds like I should be ok!
Old 07-14-2016, 01:40 PM   #5
vin63
vin63's Avatar
Yep, my front tire is 27 inches tall in the photo, so that sounds about right...double check just in case.
