Old 07-15-2016, 01:57 AM   #1
Radiatta_71
Radiatta_71's Avatar
Re: Anyone running ORD custom leafs?
I had a set on a short bed chevy. they are great offroad lots of flex. too soft for the street though. But I also had sloppy steering which magnified it.
I sold the truck and kept the springs so I think I'm going to put them on my Blazer but will add a sway bar.
Radiatta_71 is offline   Reply With Quote
Old 07-15-2016, 10:34 AM   #2
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by tjsblazer View Post
ORD specs the springs but they are purchased through Alcan springs down the road from them. Between Alcan in CO and Deaver in CA they are probably the most popular custom springs for 4x4. They build them the same general way which is thinner gauge, higher leaf count and they are one off custom based on many different criteria that you provide.
ie. usage, ride height, locations on winches, spare tires, larger fuel tanks, typical passenger and cargo weight, hard top on or off, axle align to opening, etc.
I bought from ORD because I let them do all the spec work with Alcan so it was easier for me and ORD definitely knows Chevy 4x4. I have also heard similar good things about Deaver so I think you could get either depending on your location and they would be a similar experience.
I don't remember them being as much as you stated. I had honestly thought about 1/2 of that but that was for the springs only. I guess once you start adding shackles and bushings and new shocks it starts to add up. Bear in mind the shackles and bushings and shocks you would probably do with any springs. Yes still much spendier than a mass produced off the shelf.
That price included resevoir shocks also. Those are 200 a pop. I do plan on having a winch one day and i want it set up for hard or soft top. I will let them all know that. Once i get my broncobob cage in, i will get the suspension ordered.
I want soft, especially for high speed sand. Mine rides so ridiculously hard right now its laughable.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
