Old 07-15-2016, 02:05 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: WTB 71 C-10 in-bed spare tire carrier
Looks good to me Jay, I'd like to buy it. Is that hook and wing nut original? Anyway. I'll send you a PM. Thank you.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-15-2016, 10:45 PM   #2
Clatterville trolley
Clatterville trolley's Avatar
I'm not sure that is the original part to hold tire to bracket, but it will work. I checked to see that it would hold to the bracket in such a way that the tire could be attached and it (crook) hooks into a hole inside the slot and then points the correct direction to go through spare rim. Hope that makes some sense
Clatterville trolley is offline   Reply With Quote
