Old 07-15-2016, 01:51 PM   #1
eighteenninetytwo
Locking differential option on my Blazer
in checkign my SPID turns out that my Blazer originally HAD a locking differential on it form factory.
Questions:
1. Were these just at the rear?
2. Am I right to assume that this was an automatic locker and only engages IF one wheels is starting to spin (in mud maybe?)
2. How do I determine if this is still fitted or has been replaced with another differential?
eighteenninetytwo is offline   Reply With Quote
Old 07-15-2016, 02:40 PM   #2
buffydores
buffydores's Avatar
Re: Locking differential option on my Blazer
Questions:
What year is your Blazer? The factory unit would be the infamous Eaton G80 Gov-Lock. Has a tendency to grenade the whole carrier under full throttle situations. You'd need to pull off the cover to identify it. If you want to feel confident I'd recommend a Detroit Truetrac to replace it.
Old 07-15-2016, 03:50 PM   #3
eighteenninetytwo
1975 K5 Cheyenne !! its had lots done to it over the years, (some of it even good), so i can't be sure the rear diff isn't replaced anyway. What would I look for??
Old 07-15-2016, 04:00 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
Here's a pic. They break pretty easily if you spin the tires much.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-15-2016, 04:31 PM   #5
eighteenninetytwo
I assume that there were different available ratios on these? My SPID states 3.73 Ratio.
Old 07-15-2016, 04:31 PM   #6
68Timber
68Timber's Avatar
Yes.
John
74 Honda Z50 build
