06-26-2016, 03:14 PM | #2076 |
Re: Donz '65 SWB Stepper Budget Build...
Looking good in the tent dude.
Vince Galatians 6:14 62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086 "If it's too loud, you're too old" |
06-27-2016, 07:50 AM | #2077 | |
Thanx Vince... Hope to see some Garage Journal entries on your shop updates...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
06-27-2016, 08:09 AM | #2078 |
Planned on some spaghetti time the past couple of nites... between evening Thunderstorm Saturday and other complications last night... no wiring progress... Arkansas summer has arrived Full Force, the last week or so has seen the heat index hovering between 105 and 115F, no shop w/ AC and working on truck out in heat equals little truck time for this old guy...
While browsing fb yesterday morning, I ran across a truck guy in GA with this dilemma... seems the PO of his '64 hacked up the heater box for some unknown reason... Untitled by Donald Olivo, on Flickr I happen to have a spare thanks to Jonathan (1963C10)... so this week this will be on it's way to GA... I also pointed the guy here... Untitled by Donald Olivo, on Flickr While digging through my parts stash, to pull out the aforementioned heater box, I found this license plate bracket... Untitled by Donald Olivo, on Flickr Complete with glass lens... Untitled by Donald Olivo, on Flickr Disassembled Untitled by Donald Olivo, on Flickr Bulb socket clean and in working order... Untitled by Donald Olivo, on Flickr I even found the cork gasket for the lens is pliable and ready for service... Untitled by Donald Olivo, on Flickr After a little hammer and dolly work I masked off the socket and began the paint process... Untitled by Donald Olivo, on Flickr Untitled by Donald Olivo, on Flickr Painted the inside of the lens cover white... Untitled by Donald Olivo, on Flickr Here's a pic of the back of my gauge cluster, with a new box of bulbs for illuminating it... prepping for more spaghetti work... Untitled by Donald Olivo, on Flickr I will post pics of the re-furbbed License plate bracket as soon as the paint dries (humid so sloooooow process) That's all for now guyz...
06-27-2016, 10:20 AM | #2079 |
Looks great brotha! Looking forward to the finished results!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-08-2016, 05:15 PM | #2080 |
Worked through the holiday weekend... and in the evenings I've been accomplishing some honey-dooz, in order to facilitate some truck time...
Over the past few days, I've started getting back after the wiring and also addressing the issue of the clutch pedal being about an inch and a half or more taller than the brake pedal... The wiring in the cab and front end is almost complete... the alternator still needs to be wired and the front and rear lights are not hooked up due to the fact that the front clip and bed are still separate from the cab and frame... I also need to purchase a fuel sending unit from LMC, as that is where the tank came from... On to the pics... This was the temp when I called it a day today... thankful for a tent and fan and plenty of ice water... Untitled by Donald Olivo, on Flickr for me mates across the pond... Untitled by Donald Olivo, on Flickr Hard to tell from this angle, but the clutch peal is now about 3/4 of an inch taller than the brake... more better in my world... Untitled by Donald Olivo, on Flickr The Gauge Cluster wired and in place, need to clean up bezel and find the screws... Untitled by Donald Olivo, on Flickr The copper line to feed the oil pressure gauge waiting for hookup... Untitled by Donald Olivo, on Flickr Next up is to wrap all this and put in it's home up under the dash... Gonna remove the seat so I can get myself in the proper position to make this job a tad easier... Untitled by Donald Olivo, on Flickr Once I get the wiring settled under the dash, I'll be focusing on the brake lines, clutch pedal linkage, and then getting the front clip and bed installed... Been pondering the bed floor, and think I'm going to steal Coulter's hinge idea...
07-08-2016, 11:19 PM | #2081 |
Woohooo! Spaghetti time!
07-09-2016, 03:57 AM | #2082 |
Looking good Don . At this rate I think you might be driving to Clem's this year . Look on the bright side with that temperature at least you have a pool .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
07-09-2016, 08:18 AM | #2083 |
She's almost ready to roll Don!
07-09-2016, 11:20 AM | #2084 |
You got it going your way now.
It has been on the warm side around here. Do you have a rubber bump stop for your clutch pedal? It mounts like the brake light switch in front of the pedal. Back in the day a lot of times it was missing and the clutch pedal would be higher than the brake.
07-09-2016, 01:31 PM | #2085 |
Rollin' Old Skool
Keep it up Don, & you'll be rolling before you know it! It's been really hot around here as well. Be safe out there.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
07-12-2016, 08:14 PM | #2086 |
Thanx guyz... I am getting ready to drive this soon...
I posted this question and look forward to wiring help... If you have info on this subject, please click this link and reply... http://67-72chevytrucks.com/vboard/s...=1#post7651171 I picked up this connector today and need some advice on how it should be wired... Untitled by Donald Olivo, on Flickr Thanx again for looking in...
07-13-2016, 03:43 PM | #2087 |
Thanx to member Notsolo I now have the info I need to wire the alternator correctly...
I have a resistor on order and know which wires need to be hooked where on the regulator plug... Resistor should be here Friday... So this morning I rolled the truck outta the tent, removed the seat, so I can fit myself under the dash to finish sorting the cab wiring... After removing the seat, the in-cab fuel tank disappeared... Untitled by Donald Olivo, on Flickr The filler hose, probably original equipment pulled apart upon tank removal... Untitled by Donald Olivo, on Flickr I then cut part of the brackets in lieu of drilling spot welds... ...they are now ground smooth and waiting for me to paint in order to finish covering any and all yellow from the previous paint scheme... Untitled by Donald Olivo, on Flickr Not sure how I'm going to deal with this hole, notice the spaghetti waiting to be tucked away up under the dash... As for the hole, I've an idea up me sleeve, just not a complete idea... Untitled by Donald Olivo, on Flickr Waiting for the temp to start on the downward trend a bit later today before tackling the spaghetti... Here's an Arkansas sunflower who's decided to wear dreads... Untitled by Donald Olivo, on Flickr 98% of the cab and engine wiring is complete...please don't ask for the formula to reach the %age point... Couldn't answer that one anyway... till next time...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 07-13-2016 at 03:44 PM. Reason: remove duplicate pic |
07-13-2016, 04:34 PM | #2088 |
Surprised you did not post up the other pic you shared......
Progress again. Love the sunflower, as you know, love my garden too.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
07-13-2016, 05:06 PM | #2089 |
Look for the other one on Bomp's Selfie thread... Here's a link, join the fun...
http://67-72chevytrucks.com/vboard/s...84#post7652184
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 07-13-2016 at 05:17 PM. Reason: add link |
07-13-2016, 05:48 PM | #2090 |
Truck is looking great brotha!
And the "other" picture...... Just started blasting on mine....have some tweaking to do with my blaster. lol And lot's of little holes to fix, but soon I should be priming the bottom I hope. Probably next weekend.
07-15-2016, 10:06 PM | #2091 |
The resistor showed up today, as well as the helm joint needed for my clutch linkage...
Time to start gathering my brake lines...
07-18-2016, 10:23 AM | #2092 |
I'd have to look through my thread for the exact number, but over the past 50 years the floor of my cab accumulated in excess of 42 holes...
07-18-2016, 02:00 PM | #2093 |
Stay cool and near the pool, brother... we got a hot week ahead.
Looks good and great to see the progress. |
07-18-2016, 03:48 PM | #2094 |
Coming right along! Looking good. Stay in the shade this week brother. It's gonna be a hot one.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
07-18-2016, 08:47 PM | #2095 |
Looking good Don.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
07-18-2016, 08:49 PM | #2096 | ||
Thanks guys... Today was a warm one for sure... Rian was texting me pics of his car thermometer reading 27C in Jolly Ol' England, so I had to reply with an Arkansas summer reading... Untitled by Donald Olivo, on Flickr Here's the thermometer reading in my shed... Thank goodness for fans... Untitled by Donald Olivo, on Flickr This is the resistor and heim joint that showed up Friday... Untitled by Donald Olivo, on Flickr Earlier in the day I dropped by a muffler and welding shop in town and picked up a piece of 3/4" steel rod... Untitled by Donald Olivo, on Flickr ...cut to length, 3 &1/2", drilled each end and tapped to 3/8x16 threads... Untitled by Donald Olivo, on Flickr Painted and ready to install on clutch pedal... Untitled by Donald Olivo, on Flickr
07-18-2016, 08:53 PM | #2097 |
Thanks Brother!!! Gonna try and get the resistor wired in for the Alternator feed one evening this week, plus run the sensing wire, that will be all the cab and engine wiring complete... next step, finish the clutch linkage and focus on brake lines... will be ordering my fuel tank sender soon, then get this thing road worthy...
07-18-2016, 10:16 PM | #2098 |
Way to be on it. Even through the heat.
07-19-2016, 12:49 AM | #2099 |
You certainly are all over it now Don.
Looking great.
07-19-2016, 08:40 PM | #2100 |
Friend of mine lives in Siberia. The weather is a lot cooler right now than here. Lol. But I'll pass on winter there. Brrrrrrrr. But summer seems nice.
Tags |
65 swb, c10, step side, tattoo |
