Old 07-11-2016, 06:55 PM   #1
Mikecc6
66C10 Floor Patch Panel
I need some help. I have searched many threads and can't find the answer.
I am fixing some rust issues on the drivers side floor pan. I have removed the crusty floor piece and cut the patch panel to fit. My question is, what do you do at the pinch weld where the floor meets the firewall?
Do you overlap the patch panel over the pinch weld joint and weld?
Do you bend the front of the patch to meet the upper piece and spot weld like original?(I have no idea how to bend the panel to fit)
Or do you cut the patch panel off flush with the firewall piece and weld the joint.
Or ???????
Any help would be greatly appreciated. I am stuck.
Mikecc6 is offline   Reply With Quote
Old 07-11-2016, 07:37 PM   #2
vince1
Re: 66C10 Floor Patch Panel
After having overlapped and welded I think cutting and butt welding would be better. Of course that might be easier said than done in keeping the joints tight.
Are you doing rockers under the doors. Try and keep those original height.
vince1 is offline   Reply With Quote
Old 07-11-2016, 11:10 PM   #3
Mikecc6
Yes, I am doing the rocker panel.
Old 07-12-2016, 12:09 AM   #4
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Here is what I did. My patch panel fit just like yours. I had a left over inner rocker from another truck and used it. I cut the floor pan almost flush with the pinch weld and took my leftover piece that was a 90 degree angle about 1" long on each side and flattened it down a bit to meet the angle of the floor and fire wall. i then drilled some holes and clamped it at the pinch weld and burned it in. at the floor seam it was butt welded. Hope this helps. I liked the idea of keeping the 90 degree pinch weld as I feel it gives it some strength at your feet when your stomping on the pedal.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 07-12-2016, 12:17 AM   #5
CHIZZLER
CHIZZLER's Avatar
Another pic.
61-crew cab D-max
Old 07-12-2016, 06:49 AM   #6
Mikecc6
Thanks Chizzler. I could bend a piece of 16 ga and then cut to fit. The pics are very helpful.
Old 07-16-2016, 10:20 AM   #7
Mikecc6
Had a friend bend a 90 in a piece of 16ga scrap. Trimmed floor patch panel back about an inch. Cut the bent piece to match, clamped and butt welded together.
Thanks again Chizzler. Worked well!
Old 07-16-2016, 10:27 AM   #8
CHIZZLER
CHIZZLER's Avatar
No problem. Lookin good.
61-crew cab D-max
Old 07-16-2016, 05:00 PM   #9
ImpalaJim
ImpalaJim's Avatar
Im going for a custom semi rat look Im doing it seamless but with the body lines and Im going to instaed of carpet im going to bed liner the floor
I welded the seam across the hump as well, and started across the back of the cab also
ImpalaJim is offline   Reply With Quote
Old 07-16-2016, 11:51 PM   #10
andyh1956
What are the gizmos called that is holding the panels together & where did you get them? I have some for aircraft work but they aint strong enough for 16-14 gauge steel. Thanks
andyh1956 is offline   Reply With Quote
Old 07-17-2016, 11:05 AM   #11
Mikecc6
Butt Welding Panel Clamps. Bought them at Harbor Freight. Eastwood and Northern Tool also have them.
