Closed Thread
Old 07-17-2016, 07:33 PM   #4001
66clow
66clow's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by In The Ten Ring View Post
Sparkplug holders
Are your heater core's inlet and outlet tubes sealed around with caulk?[/QUOTE]
It is some type of rubber caulking. the po said it is leaking around the bottom inlet. Hadn't gotten around to check it out. I think it is some work to get it out.
66clow is offline
Old 07-17-2016, 08:18 PM   #4002
Put heads on. Discovered one bent push rod. Put headers on and spark plugs in. Went to a buddy's and got push rod for tomorrow to hopefully button up.
special-K is offline
Old 07-17-2016, 08:40 PM   #4003
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Spent 3.5 hours cleaning my window regulators, only to confirm the LH side is what I figured it was, no good.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 07-17-2016, 10:47 PM   #4004
VWNate1
VWNate1's Avatar
Talking Windshield Wipers & Rain-X
Originally Posted by 66clow View Post
You live in so cal like me and giving windshield wiper advise? Lol You only use them maybe twice a year good advice tho.
Yes , because I grew up Down East where it rains constantly year 'round...
I also travel a lot so I use the Rain-X & wipers whenever I leave So. Cal. .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 07-18-2016, 01:09 AM   #4005
OregonNed
OregonNed's Avatar
A friend and I finally finished prepping the inner bedsides, front panel, inner fenders and rear wheel housings. We finished it off with my bright blue metallic paint. Now ready for the new red oak bed in a couple weeks.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 07-18-2016, 08:04 AM   #4006
Econman
Econman's Avatar
Love the color, Nate!
Econman is offline
Old 07-18-2016, 11:42 AM   #4007
Possmguts
Possmguts's Avatar
very nice... what kind of treatment did you do in the inner bed sides between the panels? Im in bed tear down mode right now...Going from steel to wood
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 07-18-2016, 07:41 PM   #4008
hamjet
hamjet's Avatar
Changed the front wheel bearings, races, and wb seal today. for the last couple of weeks I was getting a slight vibration at 55 mph and a 'chirp' or click every once in a while. thought maybe a U joint but decided to check wheel bearings 1st. no clicking and no more vibrations. happy dance..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 07-18-2016, 09:15 PM   #4009
In The Ten Ring
It is some type of rubber caulking. the po said it is leaking around the bottom inlet. Hadn't gotten around to check it out. I think it is some work to get it out.[/QUOTE]
Oh gosh, the heater core was leaking so instead of fixing the leak, he just hid it. Geeze Louise!
The heater core isn't really that big of a deal to take off, I did it, but you really need at least 1 other person. Take pics as you go and label everything.
I am about to reassemble mine.
In The Ten Ring is offline
Old 07-18-2016, 09:19 PM   #4010
In The Ten Ring
I made some progress today: I was over at my parents' house anyway so I cut out the bracket that will hold my replacement windshield washer pump. I wanted to cut it out of 1/8" steel but dad suggested I use 1/8" aluminum since he had some scrap and it would be easier to cut.
I used my Dremel tool and although the piece ended up a bit bigger than the template (usually does, right?) I think it will work fine. I am going to place it up against the washer bottle bracket tomorrow to check the bolt holes and then finish the project.
Old 07-19-2016, 10:02 PM   #4011
GR8-68
GR8-68's Avatar
Went in my air conditioned shop and sand blasted some of my small parts. Some progress is good progress
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline
Old 07-20-2016, 01:00 AM   #4012
VWNate1
VWNate1's Avatar
Exclamation Re: What did you do to your truck today? Chapter II
AC ~ in a Shop .
Next you'll be telling me they have HEATERS .
-Nate
Geezer
VWNate1 is offline
Old 07-20-2016, 06:25 AM   #4013
GR8-68
GR8-68's Avatar
Originally Posted by VWNate1 View Post
AC ~ in a Shop .
It is a small utility shop, I can't afford a garage yet
Larry
"Project 68"
paypal.me/ldgrant
GR8-68 is offline
Old 07-20-2016, 09:43 AM   #4014
custom10nut
custom10nut's Avatar
If you have water coming out of your lower fitting, then most likely your heater core is leaking.
To answer the caulking question? I don't know, mine doesn't have it, but also doesn't mean it was never there.i would think from your picture, that a black silicon sealer would work.
Hopefully one of the experts has answer
custom10nut is online now
Old 07-20-2016, 11:55 AM   #4015
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
I'm no expert but the black foam stuff is still available , I see it on Dealer and higher end HVAC Shop's repair works .
The heater core isn't difficult to replace , it's just takes a bit of time and your attention , you'll find leaves and debris in the heater box and plenums plus the diverter flap will be rusty , easy to clean and lube so it works like new again .
Keeping the heater core connected is an important part of the overall cooling system , take the time to reconnect it and do a nice job of it , you'll get zero heat bleed into the cab in Summer .
-Nate
Geezer
VWNate1 is offline
Old 07-20-2016, 12:24 PM   #4016
VWNate1
VWNate1's Avatar
Working Space
Larry ~ don't crush my dreams here , O.K. .
I grew up Down East where Garages were always cold and wet (yes , even the Dealer and Service Station ones) , moved Way Out West and was amazed and pleased to see Mechanics working out side of any building , on an in ground hoist over *perfect* flat and smooth Concrete....
I'm an old geezer now and I still work out side on a cement slab out side albeit with a canvas canopy overhead these days .
An air conditioned shop is but a dream for me, always will be .
-Nate
Geezer
VWNate1 is offline
Old 07-21-2016, 12:38 AM   #4017
un4gvn!
un4gvn!'s Avatar
This is what I do with old rusted, wrecked, dented, discarded hoods. I can unbolt this scoop from the underneath and run with out it. This scoop is made of all hood. Can you see the sections from hoods?
I tried everything to straighten out these pictures.
un4gvn! is offline
Old 07-21-2016, 01:05 PM   #4018
CST10
CST10's Avatar
Nice looking scoops. Great idea too.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 07-21-2016, 02:58 PM   #4019
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Here you go!
Those are nice and metal too! Cool.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 07-23-2016, 07:05 PM   #4020
ohboy321
ohboy321's Avatar
Finished installing rebuilt steering gear, and painted the driver side fender with rattle cans (was black primer). Also painted the bumper white and the grill trim/bezels silver...all were painted a redish color many owners ago.
The steering gear made a huge difference. I painted the fender a jeep orange...all I can say is it isn't black anymore. I try to do a few cosmetic things every weekend.
ohboy321 is offline
Old 07-23-2016, 08:29 PM   #4021
everettelane
everettelane's Avatar
Ordered my new wiring harness, Looks like a pretty well put together kit I know its better than my existing one. American Autowire 1969-72 Chevy Pickup Truck Wiring Harness Kit 510089
everettelane is offline
Old 07-24-2016, 10:01 AM   #4022
Possmguts
Possmguts's Avatar
Got these at the swap meet this weekend... Still not too sure about them. Wonder what doing them completely black would look like? Doing them the orange body color would probably be a bit much, but all black might work... thoughts?
Old 07-24-2016, 11:47 AM   #4023
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Ha! You asked this crew form thoughts? Dangerous, P.G.!!
I know what *I'd* do....So, that's as good as I can say.
I'd not put a ton of energy into them...Wash 'em and clean 'em up a little, get rid of the raised white lettering on the tires, and then run 'em.
Later, if I liked what they looked like, I get some fat tires for 'em (if the ones on there need to be replaced for size/tread reasons).
Don't have time this a.m. to "do it right". But in a minute, I'll post your rendering with a quickie install on the rear.
https://magwa.smugmug.com/DrivewayRAT-32015/i-4fmKrWb
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 07-24-2016, 12:58 PM   #4024
RickDeVon
RickDeVon's Avatar
Very nice blue...you got a name and paint code...
71 C10 I6 250 TH350 power steering and power breaks...
RickDeVon is offline
Old 07-24-2016, 01:00 PM   #4025
Possmguts
Possmguts's Avatar
lol.. I know, Im a glutin for punishment... but with the truck being a full frame off and still has a ways to go, they wont be ran on it without being restored first. I can have my tires mounted on 2 of them so I can at least get an idea before I dive full in I guess..
Closed Thread
