07-15-2016, 02:02 PM | #2426 |
Re: What did you do to your truck today part III
Project Fix-a-Leak.
Radiator started leaking around the top seam. The radiator did not look to be in the best condition so I replaced it with an American Eagle 2 row with 1 inch tubes. PO had homemade fan guard/shroud, so I replaced it with a 3 inch chrome unit. I also had a small oil leak from the back of the intake manifold. I removed the manifold and installed new gaskets. At the same time I installed cast aluminum valve covers and also a new distributor. Got it all finished up this morning for a Friday night and another Saturday afternoon cruise in. Test drive to town and back showed no oil leaks. |
07-16-2016, 09:03 PM | #2427 |
Working on cleaning up the paint, got the tail gate done. First time this has probably ever been done to this truck. Doesn't look to bad for 50 year old paint.
If you don't like this pound sand ..... |
07-16-2016, 09:44 PM | #2428 |
1965 c10 cuztom dually build |
07-16-2016, 10:00 PM | #2429 |
I replaced the trailing arm bushings on my '66 with polyurethane. It really tightened up the rear end.
07-17-2016, 01:07 AM | #2430 |
Been sand blasting my 66'c cab. More rot repair than I wanted to see but oh well.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-18-2016, 12:41 AM | #2431 |
Scraped out the flooring in my 66. Under the old rubber mats was what looked like tar paper that had baked into the floor. What a #@&% to remove.
Put down some Keep Cool insulation to quiet my tin can. Seems like a good product but after a few hours of using spray adhesive I can see why the other self adhesive products are more popular. At least it was only $60 for the 5x10 roll. I'll probably use dynamat or something similar for the inside of the doors.
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
07-18-2016, 09:50 AM | #2432 |
Drove it!
07-18-2016, 11:06 AM | #2433 |
I finally pulled the old rotted plywood out that got "temporarily" installed 20 years ago, and got new thicker and sealed plywood "for now"
the notch on the right side is where my leg went through... Got the left side in... finished for now. need to add a piece of strap so I can bolt down the end of the panels.
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
07-18-2016, 01:25 PM | #2434 |
got the trans mount made, able to attach to the t-bar cross member for the th400 and was able to have the engine and trans sitting in and supported by the truck for the first time! also couldn't resist slapping a few on the finished parts on the engine just to get a picture (and vision)
3" lowering spring in the rear to compliment the 2.5" drop spindles in the front.
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
07-18-2016, 03:50 PM | #2435 |
So there isn't a pot of gold at the end of a rainbow... there's a C10. Just as well I suppose. Cool pic!
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
07-18-2016, 08:53 PM | #2436 |
Worked on fitting up the front tub on the passenger side. I'm happy with the way this one is fitting so far. It's not perfect but it's not bad considering I'm no sheet metal guy. I did the driver's side a while ago, but am not happy with the outcome. So looks like I'm going to have to redo it. Hopefully the inner fender will be salvageable.
[IMG][/IMG] [IMG][/IMG] |
07-23-2016, 12:06 AM | #2437 |
Replaced the rear pinion seal and extended exhaust to dump at rear axle.
07-24-2016, 04:19 PM | #2438 |
I put on 4 new wheel cylinders and the three rubber brake hoses and gravity bled the brakes .
I put in a cross flow rad from a V8 Vega . and I took the truck for the first ride on the street since I put it together . |
07-25-2016, 11:03 AM | #2439 |
Installed an MSD ignition control box in my GMC.
07-25-2016, 05:36 PM | #2440 |
It's Better With Nitro
Machined the shifter arm and tap base to fit my North Coast Brewing Co. porcelain beer tap for my shifter handle...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
07-25-2016, 08:47 PM | #2441 |
Started building my wiring harness...
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
07-25-2016, 11:15 PM | #2442 |
Nice job! I had done the same on the jockey shifter of an old Harley. Most beer tap handles are too long inside the truck but that one fits nicely.
07-25-2016, 11:39 PM | #2443 | |
07-27-2016, 06:17 PM | #2444 |
Installed Vintage Air
07-28-2016, 04:10 PM | #2445 |
07-29-2016, 08:25 AM | #2446 |
07-29-2016, 05:11 PM | #2447 |
07-30-2016, 07:25 PM | #2448 |
Moderator
Worked on assembling the chassis today and yesterday.
07-30-2016, 08:48 PM | #2449 |
I just bought a 1966 GMC 1-ton. It is low mileage, the owner says that the 9800 on the odometer is correct. It runs by pouring gas in the carb and today I pulled the tank. UCK, nasty and rusty. Ordered a new tank and sending unit today. I will start a build thread and post some pictures. It is an original stake bed with the original sides.
07-31-2016, 11:25 PM | #2450 |
Unfortunately I did this:
