60-62 power steering bracket pic
Does anyone have an "installed" picture of the bracket that Capn Fab makes for the power steering conversion. How many of the original holes are used on the bracket and how many have to be drilled? I know I have to notch the top of the frame to fit the forward-most top bolt hole, but not sure how the others line up.
Thanks in advance... |
Re: 60-62 power steering bracket pic
look up in the faq under p/s
ron |
60-66 Nut
I believe I asked you before your purchase if you were aware what was involved with the '60-'62 power steering kit. There are links in this post.
http://www.67-72chevytrucks.com/vboa...&postcount=626
#4 | |
![]() Quote:
I only used 1 existing hole. I will see if I can dig up some pics.
Either way, its probably the best upgrade I have done!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
