Old 07-18-2016, 07:43 PM   #1
cardreams
1968 A/C question
Hey guys my 68 has factory A/C is there a system out there that I can clean up or delete the firewall and clean up under the hood and still use the factory on the inside ?
cardreams is offline   Reply With Quote
Old 07-19-2016, 01:17 AM   #2
F.A.A.benny
Re: 1968 A/C question
Cant really do that because the blower motor is on the engine-side of the firewall. Eliminating the ac box which houses the blower motor and you have no air flow through the heater box. If you wanna smooth the firewall you have to go aftermarket like Old Air Products, Classic Auto Air, or Vintage Air
F.A.A.benny is offline   Reply With Quote
Old 07-19-2016, 07:55 PM   #3
mike16
I have seen something like what your describing. What I seen was for a 70+ comaro or f bird. i dont know it they got them for trucks. seems like a missed market segment
mike16 is offline   Reply With Quote
Old 07-19-2016, 08:11 PM   #4
F.A.A.benny
Wonder where it got its air from. The fbody all the way up to the third gen has basically the same factory ac layout (ac box on engine-side of firewall, heater box inside)as gm trucks from 67 until the end of the square body. Heater box gets its air from the ac box. Remove ac box and smooth firewall, closes inlet for air to the heater box.
Old 07-19-2016, 08:23 PM   #5
F.A.A.benny
I see its been done on 4th gen fbodys but in their system, the blower motor is housed inside the car on the heater box.
http://ls1tech.com/forums/lt1-lt4-mo...-heat-how.html
Old 07-19-2016, 09:11 PM   #6
Bigdav160
Bigdav160's Avatar
A/C delete box
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-19-2016, 09:26 PM   #7
F.A.A.benny
I apologize as I misread the op's question. For some reason I got it in my head that he wanted to smooth the firewall. That ac delete box posted above is what's needed if just wanting to clean up the firewall but not smooth it completely
Old 07-19-2016, 09:30 PM   #8
68bowtie
68bowtie's Avatar
totally agree. i would like to clean up my a/c firewall too (shamers go away) but keep the defrost function. nothing out there on the shelf that i can find. i haven't given up the idea just yet.
Old 07-19-2016, 09:33 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1968 A/C question
No need to apologize you are correct per his statement. He wants a smooth fire wall but have the AC.
Unless he goes aftermarket he will not find anything that I know of.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
