Old 07-18-2016, 10:47 PM   #1
kevmic28
kevmic28's Avatar
Starte/battery issues
Ok here it goes. 70 Gmc 350 with ac and elec fan, ran fine no issues other than heat soak on the starter when I parked it and tore it apart. Its back together a year later now but I am having issues.
My son drives it now, first truck.
Anyways, started having starting issues. I figured it was heat soak on the starter from the headers. So I replaced the starter. Truck ran fine for a month. Then started having starting issues. Had the 5 year old battery checked and it had a bad cell. New battery, back to starting fine.
He added a stereo and amp and back to starting issues. So we replaced the old alternator last weekend. Back to starting fine. Also replaced the negative batt line to the engine.
This past weekend it started having problems again. Replaced the starter again yesterday after having it tested and saying it was bad. Also added a heat shield. Started and ran fine yesterday and today until this evening.
Tonight he jumped in and it fired right up. He backed down the driveway, hit the brakes and it died. Would not start back up. Had to jump start it to get it back up the driveway.
Tried to start it again and nothing. Stereo off, ac off, elec fans off, had to sit for about 5 minutes jumping off from my Dodge ram for it to turn over.
Checked the pos lead to the starter and no power loss. Check the alternator line and no power loss from the alt to the bat.
Took the batt to get tested but they said it needed to be charged. Dead battery. So its on the chager now. Gonna get it tested again in the morning.
I am stumped. I cant find any drains. At 12.5 volts and it will start. 12.3 and no start. Also with engine running at idle the alt output sits at about 12.8 with the fan on and 13.8 with the fans off.
Bad starter or bad battery or what?
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 07-18-2016, 11:37 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Starte/battery issues
Does the new stereo have a capacitor ?
Old 07-18-2016, 11:51 PM   #3
kevmic28
kevmic28's Avatar
No capacitor. After talking to my son tonight he told me sometimes when he hits the brakes hard the radio dies. So I am thinking there is a wire grounding out in the radio harness.
But I wouldn't think that would instantly drain a battery and kill an engine.
I'm going to disable the stereo in the morning to see if that eliminates the issue.
1970 GMC truck
Old 07-19-2016, 12:34 AM   #4
graymond1967
graymond1967's Avatar
May want to consider a higher amp alternator. With the fans and stereo on, you should still be at 13.7 volts. The fans are draining the battery when they are running and making it hard to start. I had a similar issue with my fans, went with a power master 140 amp, upgraded the wiring and starts fine, fans run, msd works well, and starts. With the fans and lights on, I am at 13.7 volts at idle.
Recheck your grounds by the horn relay and from the engine to the firewall.
Ray
1967 Chev C10, in the family since 1967, iron head 502, turbo 350, white with red, unrestored.
1970 Acadian SS350, 350 with muncie 4 speed, 12 bolt, best time 13.414 @ 103.72
graymond1967 is offline   Reply With Quote
Old 07-19-2016, 03:51 PM   #5
kevmic28
kevmic28's Avatar
Ok. I checked it all this morning. Lights on and stereo pumping the alt was fine at over 14. But when I turned on the ac it dropped to 11. Im thinking when I put it back together I didnt connect the wires correct. Its a vintage air ac setup. but the ac and fans worked fine for the last couple years until I tore it apart for rust repair.
Tonight when it cools off I will check into the radio to see what is grounding out there.
1970 GMC truck
Old 07-19-2016, 03:59 PM   #6
davepl
davepl's Avatar
While under cranking load? Because there will never be voltage drop without a load.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-19-2016, 04:22 PM   #7
kevmic28
kevmic28's Avatar
Yes under load. The power drop was minimal.
1970 GMC truck
Old 07-19-2016, 05:01 PM   #8
kevmic28
kevmic28's Avatar
Im replacing the alternator with a 140 amp. I had a 100 amp alt that I replaced and I just did some checking and found out that the 100 amp alt that I thought I was buying is really a 63 amp. That's what I get for trusting the guy at the parts store and shame on me for not making sure I knew what I was getting.
1970 GMC truck
