Old 07-16-2016, 09:22 PM   #176
Gregski
Gregski's Avatar
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
Originally Posted by bluek5 View Post
That's weird I thought I posted a picture of the transmission on the previous post. The trans and shifter could probably be had for $150 or less.
You did but wheres the Hurst shifter and linkage in the pic? It goes where those 3 triangle holes are
Gregski is offline   Reply With Quote
Old 07-16-2016, 09:26 PM   #177
bluek5
bluek5's Avatar
I didn't get a picture of it. It is laying in the bed of the truck also. It has the round shifter and not the embossed Hurst.
bluek5 is offline   Reply With Quote
Old 07-16-2016, 09:41 PM   #178
Gregski
Gregski's Avatar
Yes that is the correct shifter, GM was too cheap to buy the actual Hurst stick so they made their own and just welded it in in the factory
Important, do you see the three shifter fingers? They are also GM and impossible to find, get them, get it all and the tailshaft
Old 07-16-2016, 10:01 PM   #179
bluek5
bluek5's Avatar
I may have to do that. If someone local sees this and wants to grab it feel free. I have a problem collecting parts that I don't really need. It is in the bed of a bronze colored 84 Chevy at the Tear-A-Part on Redwood Road in Salt Lake City.
Old 07-20-2016, 09:34 AM   #180
65Robb
I have been doing research on this transmission for like 10 months and have been looking for one as well so far no good leads.
65Robb is offline   Reply With Quote
Old 07-20-2016, 02:34 PM   #181
hatzie
Moderator
hatzie's Avatar
Might be worth the 3.5 hour trip to Salt Lake City.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-20-2016, 02:37 PM   #182
65Robb
Its tempting lol I might have to call the yard see if they still have it
Old 07-20-2016, 02:50 PM   #183
65Robb
Hey bluek5 was that a complete unit shifter an bellhousing?
Old 07-20-2016, 03:05 PM   #184
bluek5
bluek5's Avatar
I think the bell housing is on the engine. It was a hydraulic clutch. You could try calling them 801-886-2345 , I really doubt if they could tell you if it was still there. The cover had been taken off of the transmission, so I would plan on it only being a core. I will probably go in there on my way to work Friday afternoon.
Old 07-20-2016, 03:22 PM   #185
65Robb
Yeah being a pick a part be kinda tough to tell lol yeah that be cool if its there just needs a shifter lol if u go could you get some pictures of it I wanna swap one in my 65 c10
Old 07-20-2016, 03:28 PM   #186
bluek5
bluek5's Avatar
The shifter is there also. This one is out of a 4x4 so you would need a transfer case with the round pattern or an adapter. I
Old 07-20-2016, 03:29 PM   #187
65Robb
Dang it lol I need a 2wd lol defintly be worth picking up if cheap enough
Old 07-20-2016, 05:49 PM   #188
bluek5
bluek5's Avatar
Here is a transmission and bell housing for sale on KSL in Roy, Utah
http://www.ksl.com/?nid=218&ad=40692...chevy&ad_cid=6
Old 07-20-2016, 05:51 PM   #189
65Robb
Ill have to check that out for sure looks like all it needs is a shifter. You said the one in slc had a shifter?
Old 07-20-2016, 05:56 PM   #190
bluek5
bluek5's Avatar
Yes, the shifter was in the bed with the transmission. Cars rotate through pretty quick sometimes.
Old 07-20-2016, 06:16 PM   #191
65Robb
Yeah I bet I wonder if the shifters r the same from 2wd to 4wd
Old 07-20-2016, 06:20 PM   #192
bluek5
bluek5's Avatar
Maybe someone will chime in, I would say yes. If you are serious I could grab the shifter for you.
Old 07-20-2016, 08:48 PM   #193
Dazzoman
I did search the forum but could not find anything relevant.
So word on the street is the 1980-85 two wheel drive trucks may have had the 4-speed New Process NV833 overdrive manual transmission. (this being a popular Mopar transmission)
1st = 3.09
2nd = 1.67
3rd = 1.00
4th = 0.73
I currently have the 4-speed Saginaw Muncie SM465 manual transmission, which only has 3 gears, the Low being useless for me and my driving needs. So it's just a practical 3 speed with a 1.00:1 tallest gear.
First Gear - 6.55:1
Second Gear - 3.58:1
Third Gear - 1.70:1
Fourth Gear - 1.00:1
Reverse - 6.09:1
Have any of you done the swap, how difficult is it? Can I use my old bellhousing?
here's some pics off the InterWebs
Yes and I heard about an trans called the NR440 that is an 4th geared overdrive and these came out around 1981 . The tranny you are talking about looks a little like this one . Did you have any results with that swap ? I have an 3/4 ton 1966 GMC w/ Muncie 4 speed, 292 6 banger . The Muncie finally needs replacing but is useless on the freeway ( Its time ) .in looking for an replacement that gives overdrive and the same indstructable wear factor .
Dazzoman is offline   Reply With Quote
Old 07-20-2016, 08:54 PM   #194
Gregski
Gregski's Avatar
Yes I did the swap and the results are amazing, it's a difference of night and day, the first gear is now usuable and the overdrive is just brilliant. The third gear is perfect for down hilling without riding the brakes too. The details are in my build thread, it's quite long already but skip till you find it somewheres in the middle I think
Restoring Rusty
Old 07-21-2016, 12:51 AM   #195
Dazzoman
Restoring Rusty
AHH H ! Wonderful news !
MY 66 needs it because as you know even tho the muncie 4 spd is an hammer and dependable ( mine lasted 36 yrs !! ) and I needed exactly what you reported about the first gear as usable for a change hahaha !
Is your truck an 66 3/4 ton or ? And may I ask what it can pull loadwise ?
I ask because the easy fix would have been an T5 World Class 5 speed . But it might have broke or something .
How did you address the speedometer issue if any ? Welding bracets Im sure .
THANKS for the reply !
Old 07-21-2016, 01:51 AM   #196
Gregski
Gregski's Avatar
My rig be a 74, 1/2 ton 2WD which only hauls a Christmas tree in the winter and the American flag in the summer, ha ha, in other words the truck is retired, as far as the speedo it was off when I drove 6 miles it said I went 6.5 so I switched the brown driven plastic speedo gear to a purple one, same part as in the TH350 so is the output shaft yoke, also I just took the reverse switch out of my Muncie and screwed it in to the New Process and it works fine, again ton of pics and info in my build thread
This is an aluminum trans if you want strength all you have to do is find its iron case Mopar sister and swap the guts into it, and you will have the best of both worlds, bullet proof strength with overdrive
Re read this thread I provide a link in it to Steve Dulcich doing just that: A-833 Aluminum Case Buildup - Maximum Overdrive
Old 07-21-2016, 10:07 AM   #197
D13
D13's Avatar
My 4wd one is different. Rods are heavier and shifter is offset a bit more, probably to give clearance to the t-case shifter.
Note that the shifter mounts on the tail extension on 2wd and on the t-case adaptor on the 4x4. Not sure if they are the exact same pattern and place fore / aft and crosscar. I believe the shifter itself is the same, just brackets and rods are different.
Again we need to understand, these are LIGHT DUTY trans. They are NOT Hemi 833's . The gear swap resulted in overdrive, but the price is much lower torque capacity. GM never used them on anything more powerful that the 305, think ~200hp and 300ft-lb max.
The iron case was used in the GM 4wd and it appears that the 2wd guts could be installed into it (output shafts have different lengths and splines). That helps the case wear issue but not the torque capacity.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-21-2016, 10:14 AM   #198
65Robb
Ok good to know I know that the shifters are hard to come by
Old 07-21-2016, 12:01 PM   #199
Gregski
Gregski's Avatar
According to the parts manuals there is no linkage difference between 2WD and 4WD of the same year, we had this discussion before early 80s are different from mid 80s models, I have a mix of 2WD and 4WD linkages and some spares / duplicates and they are identical
D13 are your 2WD and 4WD of the same year? I bet they is different, hence the difference
Old 07-21-2016, 12:38 PM   #200
65Robb
I just wan a manual overdrive in my 65 c10 its just got a stock bf goodwrench 350 not a power house just building a cruiser, and that's awesome that they are the same identical rods just wanna get everything ready for the winter project
