07-17-2015, 12:09 PM | #101 |
Re: Another way to skin the cat; the High Torque 292 LS swap
May be too late for that up grade on the ECM, I will be happy if I can get the compressor to turn on and off!
I do have a trianary switch mounted to the drier and will need to look up the schematic to see how it is wired
07-17-2015, 01:12 PM | #102 |
nice welds
07-19-2015, 03:00 AM | #103 |
A guy with a truck
Yes, exactly what I was looking for. Super clean. It's like you were in my brain. Love it.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-02-2015, 12:18 PM | #104 |
this is exactly how an LS swap should look. I'm really impressed with the subtle fabrications you did. Great work!
10-07-2015, 08:57 PM | #105 |
very cool! you do great work.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
11-25-2015, 03:55 PM | #106 |
Nice build
11-26-2015, 06:18 PM | #107 |
11-27-2015, 03:47 AM | #108 |
nice build, good attention to details.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
12-31-2015, 12:39 AM | #109 | |
Re: Mounts:
Would this be considered in the "stock" location or inch back etc?
12-31-2015, 12:52 AM | #110 |
Re: Mounts:
01-01-2016, 01:10 PM | #111 |
Thanks for that, I'm not sure why that seems to confuse me... must be getting older.
03-04-2016, 03:02 AM | #112 |
That is a nice build! Sleeper style for sure! My compliments to all your fab work, quite impressive.
03-04-2016, 10:59 AM | #113 |
Awesome work!
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
03-12-2016, 02:31 PM | #114 |
Incredible job!
03-14-2016, 11:21 AM | #115 |
Nice work. Fantastic job!!!!!!!!
03-20-2016, 10:24 PM | #116 |
Hey Dayj1,
Can you talk about how you set up the transmission and column shifter? Thanks |
03-21-2016, 12:10 AM | #117 |
Thanks for all the compliments!
The truck had a th350 behind a 350 when I bought it. It already had what I think is a CPP crossmember and universal column shift linkage (rod type). I reused both on the 4l60 and bought an overdrive indicator lens from speedway motors. Is that the info you were looking for? |
03-21-2016, 11:45 AM | #118 | |
03-24-2016, 10:13 PM | #119 |
Wow love this build. I like how the motor looks stock. I'm sure people give it a double take at cruise nights
87 k5 silverado 4x4 350 38k stock 77 k5 Cheyenne 2wd 5.3 4l60e project |
07-24-2016, 08:26 PM | #120 |
Just went through this build, great job!
07-27-2016, 12:57 PM | #121 |
Very nice build w/great detailed info!
07-27-2016, 03:40 PM | #122 |
Every time this thread pops up, it makes me want to rip the 5.3/4l60e out of my old '99 that is just sitting there and drop it in the Blazer looking similar to this. Unfortunately, I have too much money wrapped up in a new SBC to abandon that course. I just love the look and functionality of this, maybe on the next one.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
07-27-2016, 07:38 PM | #123 | ||
07-27-2016, 10:38 PM | #124 |
So just curious, but what ever happened to the gold '68?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-29-2016, 09:20 PM | #125 |
I need to start a build thread on it. But, at this point, I've successfully disassembled and scattered a perfectly good running truck.
This is what it looked like after I mocked up the suspension and just before I tore it down to the frame. And this is the current state of the new LQ4 in it now. |
