Old 07-23-2016, 06:38 PM   #801
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Originally Posted by namloc View Post
lookin good . Got the hood finally .That is going to change the look for sure.
Thanks and yep it will sure be a change, but I change that I like
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 07-23-2016, 07:11 PM   #802
AJCK87
Love the hood! Looks awesome. Kinda jealous, I would like to have one for my rig, really dig the look. I have a hood and it works, so got to direct the funds to getting her running hahaha.
AJCK87 is offline   Reply With Quote
Old 07-23-2016, 07:29 PM   #803
62stepside longbox
Thanks Anthony, I've got a 62 hood that is really nice if you want to replace yours
Old 07-24-2016, 08:57 PM   #804
62stepside longbox
Been working on putting my engine back together and cleaned and painted up the distributor and vacuum advance, it used to have a 1/4" of dirt and grease covering it.
Old 07-24-2016, 09:33 PM   #805
Nice work. Now she just needs to go back in so you can drive the ole girl.
Old 07-25-2016, 01:39 AM   #806
62stepside longbox
Thanks bill, it'll be a while before it gets back in as I still need to install the new crossmember and build some motor mounts but I'm getting there
Old 07-25-2016, 10:39 AM   #807
AJCK87
Hey Nik,
Distributor looks nice. What's the plan for your motor mounts?
Old 07-25-2016, 04:07 PM   #808
62stepside longbox
Hey Nik,
Thanks Anthony, I will be building something like this
Old 07-25-2016, 06:36 PM   #809
TJ's Chevy
TJ's Chevy's Avatar
That'll be a nice set of motor mounts.
Old 07-25-2016, 10:45 PM   #810
62stepside longbox
Yep they sure will, I should get started on them in the next couple days
Old 07-25-2016, 10:50 PM   #811
62stepside longbox
Started to dig into the new hood today. It's rusted right through in this spot, even the part of the inner brace is rotted out, and this is the good side of the hood
Old 07-25-2016, 10:53 PM   #812
62stepside longbox
But before I repair that I decided to do a little custom work, this seam looked a little ugly to me so I thought I'd fill it in and blend it all together. The before:
Old 07-25-2016, 10:57 PM   #813
62stepside longbox
And not quite finished but I'm getting there, it's feeling pretty smoooooth
Old 07-25-2016, 11:00 PM   #814
62stepside longbox
And then I finished off the day with some fancy artwork on the side covers. I outlined the pre existing bodylines with the green implement paint
Old 07-28-2016, 07:49 PM   #815
62stepside longbox
While I have the core support and engine out I figured it was the best time to fix the rust in the other inner fender. The drivers side I did allready almost a year ago. So here's what I'm dealing with
Old 07-28-2016, 07:51 PM   #816
62stepside longbox
So I cut it all out and prepared it for welding
Old 07-28-2016, 07:58 PM   #817
62stepside longbox
And here's the finished product, needs just a skim of filler and then I'm ready to paint, progress may slow down for the next month as I am going to be now working full time but at least I'll be getting lots more money to put into the truck $$$!
Old 07-28-2016, 09:16 PM   #818
Way better than the way down here, beer can and tar!
Nice job!
Old 07-29-2016, 01:21 AM   #819
62stepside longbox
Nice job!
Thanks bill, yep sure a lot better than a beer-can mechanic's job
Old 07-29-2016, 10:12 AM   #820
TJ's Chevy
TJ's Chevy's Avatar
Yep, now you'll know how it feels to put in 40 hour weeks. Plus Saturdays sometimes. lol But, I've found motivation in working a little each night. Gets me a bit closer. Looking good bud.
Old 08-08-2016, 01:31 PM   #821
62stepside longbox
Been working on the truck lots lately just been lacking in updates. I removed the water pump and thermostat to clean the front of the block and then I painted it up
Old 08-08-2016, 01:33 PM   #822
62stepside longbox
And then painted up the water pump, thermostat, fan, pully and harmonic balancer and got it all back together
Old 08-08-2016, 01:35 PM   #823
62stepside longbox
I painted the little indent on the timing chain cover blue to match the stripes on the rest of the engine
Old 08-08-2016, 01:37 PM   #824
62stepside longbox
With a couple of tries I was able to master the double flare, this is for the vacuum advance line
Old 08-08-2016, 01:42 PM   #825
62stepside longbox
And then I picked up this cool old spotlight from the late 40's that someone has already switched the bulb out to 12volt and it works great and Chrome is in pretty nice shape as well, best of all it only cost me $20
