Old 03-15-2004, 10:59 PM   #1
TIMSPEED
TIMSPEED's Avatar
No negative camber, yet body still drops when adding weight...
Someone tell me if this is logical thinking...
So, on the passenger side of my truck, the front fenderlip is lower than the drivers side. Also, when my two 250lb buddies get in the passenger side, the fender drops down about another 1"-1½". But when the fender drops drastically like that, the tire's camber doesn't change. If it was the SPRING that was compressing, wouldn't the camber on the tire change aswell? Therefore my thinking is that is must be the cab/body mounts that are squishing, allowing the cab/body on that side to drop.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 03-16-2004, 12:42 AM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
I doubt the body mounts are being compressed that much.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 03-16-2004, 01:18 AM   #3
TIMSPEED
TIMSPEED's Avatar
They have to be, cuz my friends dad was going to cut my coils for me (cuz I don't care, since I'm getting new ones.), and he told me to measure my frame, beforehand, and both sides (driver and passenger) were both 9¼" off the ground. Therefore we're thinking the cab/body mounts are shot.
See Them Here
Old 03-16-2004, 02:12 AM   #4
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
Could be that the frame is rusted between the bushings.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 03-16-2004, 02:21 AM   #5
TIMSPEED
TIMSPEED's Avatar
That's a possibility...my friends dad asked me if it had ever been wrecked, and I said "hell no! My dad was the original owner, so, I KNOW it's never been wrecked."
See Them Here
Old 03-16-2004, 12:39 PM   #6
BaggedC10
Under construction!
BaggedC10's Avatar
You say the fender height goes down 1-1.5"...??? My PST body mounts are roughly 1.5-2" tall. There is no way 500lbs will compress the mounts to almost nothing, IMO. Despite being original and worn out. Besides, the springs support that 500lbs, not the body mounts.
Old 03-16-2004, 01:38 PM   #7
Prerunner1982
Prerunner1982's Avatar
Tim, did you measure the frame with your friends in and out of the truck.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-16-2004, 02:14 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: No negative camber, yet body still drops when adding weight...
SLA suspesions (Short/Long Arm suspensions) by design minimize camber changes for the "normal" suspension cycle. 1" is not going to cause a major camber change. The reason you get negative camber on a bagged or spring dropped truck is because you have moved the control arms UP the amount of the drop and now you are in the area where the camber changes start occuring. Typically stock suspenions are designed to have around 4-5" of compression/rebound and when you move the suspension components up in their arc you are moving out of the engineered area of the least camber changes. The same would happen if you raised the truck except you would have positive camber.
AND BTW, it is your spring that is compressing, the whole cab would have to flex if just ONE cab mount was bad.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-16-2004, 03:47 PM   #9
TIMSPEED
TIMSPEED's Avatar
No, because with NO ONE in the truck, the passenger side fender is close to an inch lower, but the frame is the same heighth.
See Them Here
Old 03-16-2004, 05:45 PM   #10
Prerunner1982
your bushings could still be bad, but i think chris hit it. you are lucky to find a truck where the fenders are all the same height. if i remember correctly there was a post about center of wheel to fender lip distance. if i remember correctly nobody had perfect measurements... i was damn close.. one side was like 3/4" lower than all others. if all cab mounts are good, i wouldnt worry about it too much... its an old truck.
Jon
Oklahoma Roll Call
Old 03-17-2004, 12:58 AM   #11
greatdaen
Put your frame up on jack stands to eliminate the suspension from consideration. Measure your fender heights. Then have your friends get in and remeasure.
This should give you a much more objective idea of your cab mount compression.
I am also highly doubtful that you could be seeing that kind of compression in your cab mounts.
-dch
greatdaen is offline   Reply With Quote
Old 03-21-2004, 06:06 PM   #12
Low69CST
Like Captkaos said, you shouldn't see any camber change by an inch or so of travel. Get under your truck, look at the body mounts. Your rubber mounts won't give that much. They would disinigrate (spelling???) before they would give like that. Besides, you would hear the cab banging around on the frame mouns as the front bushings are only bout an inch tall. Look at the cab and frame mounts and see if they are solid. Then look at the front a-arms and have someone push it up and down. You should see it move.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
