Old 07-26-2016, 03:28 PM   #3
Orange Crate
Orange Crate's Avatar
Re: Hydroboost with Rack and Pinion
I just converted to HB brakes, but I have the stock steer gear. There is a lot of good info on pumps, pressure and flow here:
http://www.pirate4x4.com/tech/billav...ng/index2.html
If you get the pressure and flow specs from No Limit you might be able to determine if the TC pump will cut it.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch!
Orange Crate is offline   Reply With Quote
hydroboost, rack and pinion
