Old 07-24-2016, 05:41 PM   #1
canadian_diesel1964
Size of holes for Cab and Rad Mounts
I need to fab up the tops of the mounts for the Rad (x2) and Cab (x4) due to rust and the holes being worn larger...I wondered if anyone has their frame exposed if the could tell me the proper size of the holes and how far they are from the outer side of the truck on centre please..Thank you!!
canadian_diesel1964 is offline   Reply With Quote
Old 07-24-2016, 07:37 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Size of holes for Cab and Rad Mounts
Around 13/16 for the rad support. Unfortunately the other side is a bad home made mount, therefore I can't give you an accurate center to center measurement.
Old 07-24-2016, 07:58 PM   #3
canadian_diesel1964
Thank you that's a great start
Old 07-24-2016, 10:55 PM   #4
aerotruk63
aerotruk63's Avatar
For some reason the picture didn't stay in my last post. So if this happens again the front cab supports are 1.34 diameter and are slotted 1.68. The center to center measurement is 40.83".
Rear mounts are 1.04 diameter not slotted and are 42.16" center to center.
These measurements are for 63-66.
Old 07-25-2016, 06:10 AM   #5
canadian_diesel1964
right on man mine is a 63...just one question are the slotted front to back or side to side?
Old 07-25-2016, 06:43 AM   #6
aerotruk63
aerotruk63's Avatar
side to side.
Old 07-26-2016, 01:11 PM   #7
canadian_diesel1964
thank you!!
Old 07-27-2016, 05:21 PM   #8
aggie91
I'm just glad to be here!
aggie91's Avatar
Note that on the drawing, ONLY the passenger side cab mount is slotted. The driver side mount is a 1.34" ROUND hole.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
