![]() Join Date: Mar 2016
402 BBC accessory brackets
Putting a 454 in my truck from a 70 Chevelle. The brackets are obviously different (AC on wrong side, etc). Has anyone researched what model trucks/cars have the same brackets as an original 72 402 truck would've had? I would like this to look like a 402, but brackets specific to 72 trucks aren't easy to find or cheap. If a 73 Monte Carlo, for example, had the same brackets, that'd be good to know. I know my Chevelle water pump isn't right too.
Moderator
![]() Join Date: May 2007
Re: 402 BBC accessory brackets
68-72 trucks and pre-68(?) cars used short water pump brackets on big blocks. They are actually easier to find on trucks than cars.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
As a bit of trivia/info, did the small blocks switch to passenger side alternator in '69 to match the cars? Or did they stay in pre-69 configuration like the big blocks?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Moderator
Correct Alternator brackets for a big block 402 truck from 72 are 1 year only, however other years will work. Power steering and AC brackets are the same. In 68 the BB power steering reservoir had a bracket that mounted it off the fender.
i bought a big block accessory kit setup from the junkyard. Same thing, found the AC and alternator were on different sides then stock for my 72. I ended up the big block brackets from http://www.alangrovecomponents.com/Catalog.htm, including the PS pump bracket, crank pulley and water pump pulley. Oh, and ordered a new Sanden 508 style AC compressor.
The Alan Grove ppl know what they're talking about so give them a call if you're unsure which parts you need from them. |
Will a modern style AC compressor (vintage air) fit those brackets? How about an alternator I can get at autozone?
Moderator
No, only the factory a-6 compressor or the aftermarket pro6-ten will fit factory brackets. They will not hold a sanden style compressor
Cars went to long pump in 69 and alternator swapped sides then is correct.
For the 427 I am building I am using brackets for a 68 Camaro 375/396 that are all deep groove. Currently will try mounting the car PS pump but that may change... There is a reason the truck had the remote reservoir.
