07-25-2016, 10:22 PM | #1 |
Cracked exhaust manifold 396
Over the last couple of months I have noticed an exhaust leak on my 68 C20 with a 396, turbo 400. I thought it was probably a loose manifold or a collector gasket that was loose as the noise would go away once the engine warmed up.
Today I noticed that the left manifold has a crack in it! Can an exhaust manifold be welded? I know it is is cast and this adds difficulty, but how much difficulty? If I go shopping for another manifold how exclusive are bbc manifolds to trucks? Any other reasonably suggestions? The truck is fairly original and a bit of a survivor truck so I am not looking to go to headers or swap the entire exhaust system. Posted via Mobile Device |
07-25-2016, 10:31 PM | #2 |
Re: Cracked exhaust manifold 396
Is it really this simple?
http://m.ebay.ca/itm/Exhaust-Manifol...256?nav=SEARCH Posted via Mobile Device |
07-25-2016, 11:10 PM | #3 |
Yeah probably, I have seen s lot of repops. I think the big cars used the same ones.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
07-25-2016, 11:30 PM | #4 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-26-2016, 05:24 PM | #5 |
Where on the manifold should I look to find the casting number.
07-26-2016, 05:57 PM | #6 |
70+ ( Old Skool Club )
Blaine I have a new repro exhaust manifold that came with a 70 BB truck I bought a few years ago. I'm not sure what side but can check tonight when I get home.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-26-2016, 06:41 PM | #7 |
They can be welded, also.
There's a special "cast" welding rod. You cannot use a grinding disc to clean out the crack, you have to use a carbide bit. They also make a "gouging rod" that is used ahead of the welding, some how it prepares the surface for the cast rod. I'm no expert at all this, my good friend has a machine shop, showed me several years ago. It does work. Nickle rod is NOT the same thing... |
07-26-2016, 08:26 PM | #8 |
http://www.yenko.net/ubbthreads/pics...8-img_0286.jpg
How different are bbc exhaust manifolds. Part number on the side 3914613. This does not align with the ATP cross reference in the eBay ad I posted above. Posted via Mobile Device |
07-26-2016, 08:49 PM | #9 |
It is not uncommon cracked manifolds were common even in to the squares and the 88-98 style as well.
07-26-2016, 11:50 PM | #10 |
As luck would have it I have a right side exhaust manifold.
07-27-2016, 12:02 AM | #11 |
I,m needing a left one for my 72 402, I see LMC lists them also.
1972 Cheyenne Longhorn k20, 402, A/C |
07-27-2016, 01:22 AM | #12 |
07-28-2016, 12:56 AM | #13 |
The casting numbers can vary: Here's some info. most of which I lifted off SSTIM:
The following part numbers are service replacement parts. But don't expect a number in the parts manual to match a part you pulled from your truck. Overall its real simple, the replacement manifolds at the time of printing (5/79) were: 3994045 LH 333846 RH (3916178 to 3994046 to 333846) with A.I.R. this is the air pump for emission reduction (Not A/C). 343787 LH 353030 RH There is nothing on the parts manual page showing application specific parts for a 396-402 C10-30 Air Conditioned vehicle. If there were it would probably be notated w/AC, C.A.C., or C60.
