Old 07-26-2016, 11:28 PM   #626
Advanced Design
Advanced Design's Avatar
Re: 53 Surburban "Family Truckster"
Just thinking aloud...maybe mount the third seat on a platform to go above the watts link?
Rather than narrowing a third seat, can you use a second seat in the third seat position so it is narrow enough to clear the wheel tubs? The third seat, as you know, could be sold for way more than a second seat would cost.
Advanced Design is offline   Reply With Quote
Old 07-27-2016, 09:40 PM   #627
youngrodder
youngrodder's Avatar
Yes, I thought about that..i don't like the platform idea because I took so much time to hid stuff under the floor. I don't care for how it looks when you have the rear doors open. I actually thought about moving the middle seat to the rear and vise versa.... You could enter through the back doors to get access to the back seat. I have time to figure it out...ha ha
Porterbuilt is shipping my front core support mount tomorrow so I will be able to finalize how that mounts and bolt up the front fenders..
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 07-28-2016, 12:24 AM   #628
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
When i was building my burb I tried my hardest to use the 3rd seat. It was just to awkward at the position it would be in. I ended up selling it to a guy that was doing a factory build. For me 5 people was enough. Burb is looking good Marc.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 07-28-2016, 08:15 AM   #629
lower50's
lower50's's Avatar
Marc could you not mount the seat on top of the diff hump and have your legs hang just in front of the hump?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 07-29-2016, 09:05 AM   #630
Iceburgh
Iceburgh's Avatar
I know you are using the original seat frames so what I did wont help.
I ended up getting flip seats out of a S10 that originally flipped to the side.. I mounted brackets to the floor so these would flip up and down. Not very comfy, a ***** to get in and out of and then no room for any storage if someone is back there.
But it is an idea. Wont be the look you are going for with your build.
But loving what you are doing so far....keep going at it. I am glad I got mine done when I did. New position has me on the road all the time. So far I have put 40 miles on my Burb this spring /summer
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 07-29-2016, 01:50 PM   #631
youngrodder
I know that is the same stuff I'm struggling with. I'm not ready to throw in the towel yet.. I'm a slow learner
I not think so because it would put you right up against the back of the middle seat.
Thanks Jim.. Boooo to only putting 40 miles on yours. Take a vacation this fall and drive out the NSRA Nats north in Kalamazoo..
I will get more garage time this weekend.
Marc
Old 08-01-2016, 10:42 PM   #632
youngrodder
Not many people would take a rare 3rd row suburban seat and cut it up. Well you can only stare at something so long before you just have to start cutting.
The idea I had was to cut off the legs because it was interfering with the watts link and notch. Then I decided if I narrowed the seat a couple of inches it would help fit between the wheel tubs that I also need to widen. I narrows the seat 3". The ideas was to narrow it slightly so it is not overly noticeable. I was amazed at how well the seat springs and jute looked on the seats.
After I cut the seat frame tubes I used some cold rolled steel tub to reinforce where I cut. I plug welded it for strength. I was very happy with how it turned out. I will narrow the seat springs at a later date.
Marc
Old 08-01-2016, 10:51 PM   #633
youngrodder
More pics....I also noticed on of my wheel tubs had large dent in one side but not the other. At first I thought the wheel tubs were double walled. No someone along the line just filled dents with bondo...I started pounding out the dents and a bondo piece over 1" thick flew off....ha ha
I will be adding 3" to the wheel tubs to allow for a wider rear wheel.
Marc
Old 08-01-2016, 11:19 PM   #634
oldman3
oldman3's Avatar
Nice job on the seat...Jim
oldman3 is offline   Reply With Quote
Old 08-01-2016, 11:51 PM   #635
lower50's
lower50's's Avatar
No one other than all of us will ever see the difference. Nice.
1951 MG TD
Old 08-02-2016, 09:33 AM   #636
reaper71
reaper71's Avatar
Simple fix to a big problem!
nice work Marc.
Mark...
reaper71 is offline   Reply With Quote
Old 08-02-2016, 06:37 PM   #637
Advanced Design
Hey Marc, good solution, well done!
Old 08-02-2016, 09:03 PM   #638
youngrodder
Thanks Jim
Yeah, I knew I could trust you guys..ha ha
nice work Marc.
Mark...
Thanks Mark, I do think that it will help to fit it in there with the wider tubs.
Thanks Doug. I was glad it turned out. I was growing tired of staring at it...
Marc
Old 08-04-2016, 06:51 AM   #639
RockinKees
RockinKees's Avatar
Nice simple fix, no one will notice
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 08-07-2016, 10:09 PM   #640
youngrodder
I had a pretty cool truck weekend. It started on Saturday when I was convinced to go to a local car show at Gilmore Car Museum. It is a must stop if you ever find yourself going through Kalamazoo, MI. I started up a conversation with the guy with this nice AD truck. It was very well built. 675 hp out of an LS1 engine. It was in Street trucks earlier this year. Through our conversation I mentioned that I was looking for a rear suburban fender (which are very hard to come by especially in the rust belt) he mentioned a guy with all sorts of Ad parts that he was selling. He mentioned that I should not wait if it was something that I wanted as this guy is selling off stuff all the time. I called him 15 minutes later and arranged a time to meet Sunday. It was an 1:20 minute drive one way.
The first thing I saw was this 55 first series Suburban which was complete free of rust and rot and I felt the price was fair. Then as I walked around the place I kind of felt like the guy was a hoarder of AD parts...He had so many rare hard to find parts. I took pictures because words can describe....it was hard to focus on anything because everywhere I looked I saw something else.
He had (2) full suburban floors just sitting in the weeds like he grew them. The seat riser was in great shape. He had (2) complete sets of rear fenders and a few others stashed away. He had countless hoods and font fenders. I bought a rear passenger side fender (best one he had) as well as a rear splash pan complete with mounting brackets. He had a lot of 54 stuff like the blue 5 window cab.
On to the pics.
Marc
Old 08-07-2016, 10:13 PM   #641
youngrodder
More.....
Old 08-07-2016, 11:17 PM   #642
oldman3
oldman3's Avatar
Nice find on all the parts, as the old saying goes "right place and the right time"...Jim
Old 08-08-2016, 08:25 PM   #643
Advanced Design
That is a great parts find and it looks like he has parts organized in the racks. Guessing that was a fun trip!
And a rock solid Burb right in Michigan. Did he mention where it came from?
Hope he doesn't leave the seat risers out in the weeds.
Old 08-08-2016, 10:18 PM   #644
youngrodder
That's right Jim....
The Suburban came form Utah. He probably will...He did have a front flip seat and driver seat frame outside. He also had a rear spare tire carrier sitting in the dirt. He had (3) spare tire mounts from trucks in a stack outside. I kept pointing out you know how much those are worth...
Marc
Old 08-09-2016, 03:32 PM   #645
lower50's
lower50's's Avatar
Wow looks like a gold mine. They even look well organized.
1951 MG TD
Old 08-09-2016, 10:04 PM   #646
youngrodder
Yes and no....I didn't take any pics of the disorganized stuff, but there was plenty. It was all good stuff though.
Marc
Old 08-09-2016, 10:16 PM   #647
youngrodder
One other Suburban related item I'm working on is the PB core support mount. This will have a mounting plate/bracket at some point. We are working to figure out the placement of the mounting plate. I kept my original front frame section so I need to double check the placement of the core support on that piece and see how it corresponds with the PB part.
Other than this the only remaining items in development is the front sway bar (the tabs are already welded on the lower control arms as well as a steering linkage mount bracket because I will need to go with a 2 piece steering shaft to clear the headers...
Marc
Old 08-10-2016, 09:00 PM   #648
Advanced Design
Nate should give you a T shirt...ADVANCED DESIGN TRUCK PORTERBUILT DEVELOPMENT TEAM....with a pic of your Burb on it. Better yet...a jacket.
I would guess trial fitting your front end pieces to the core support...helping situate the up / down and fore / aft....would be part of the checking too?
Anyway, sounds fun.
Old 08-10-2016, 10:00 PM   #649
youngrodder
Anyway, sounds fun.
Yes not shown in the picture but I mounted up the front fenders. I still have the factory frame rails to check the position of the PB core support to the original one.
Nate, is a good dude. I find it fun to collaborate on figuring this out. Some of these wrinkles that have to be full figured out is why you don't see these kits listed on the PB web site yet.
Marc
Old 08-14-2016, 10:15 PM   #650
DeeJayNOLA
DeeJayNOLA's Avatar
Originally Posted by youngrodder View Post
More.....
Wow!!! My wallet and SWMBO would've been at odds if I'd found this gold mine. Folks keep tellin me there's a place here (Louisiana) that's like this but I've yet to find it...
Representing for the 504.
DeeJayNOLA is offline   Reply With Quote
