Old 03-15-2004, 08:15 PM   #1
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Radio cuts out on bumps or door slam
What could be causing this?
Please help electrically-inclined 73-87'ers...
Thanks.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 03-15-2004, 08:27 PM   #2
Stingray42
Woot.
Stingray42's Avatar
just a bad connection somewhere.... ground perhaps?
Clarkson
96 Chevy RCLB 4.3 2WD
Stingray42 is offline   Reply With Quote
Old 03-15-2004, 08:33 PM   #3
bpmcgee
bpmcgee's Avatar
I think he's right, but I think it's more likely to be the hot wire -- ground is through the frame, obviously. It could also be the connector at the back of the stereo which has the speaker wires.
Brian
bpmcgee is offline   Reply With Quote
Old 03-15-2004, 08:54 PM   #4
Lynx
Lynx's Avatar
I would just get back there and follow each wire and make sure all conections and grounds are good
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 03-15-2004, 09:09 PM   #5
rolson1039
like the others said bad ground and you can never have too many grounds so concieveably you could take another piece of wire and ground it to the dash and then tie it into the wiring harness at the radio plug. Also make sure the radio plug is nice and tight in its socket there
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 03-15-2004, 10:26 PM   #6
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
If it is not the factory radio, check the hot wire. Many times someone will run a new wire to the fuse box and connect it poorly.
NeCrOmAnCeR is offline   Reply With Quote
Old 03-16-2004, 03:01 PM   #7
8t5Silverado
Thanks for the help.
I figured I would try and fix this while the dash pad is out of the truck.
