Closed Thread
Old 07-31-2016, 01:17 PM   #4051
berch 69GMC
berch 69GMC's Avatar
Re: What did you do to your truck today? Chapter II
Fixing up this foam for new covers. Dodge buddies I bought last year.
http://67-72chevytrucks.com/vboard/a...1&d=1469985197
berch 69GMC is offline
Old 07-31-2016, 11:09 PM   #4052
OregonNed
OregonNed's Avatar
Finished my inner fender install today. Both painted body color. Now on to getting the bed finished this coming weekend.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 08-01-2016, 12:20 AM   #4053
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
My stepdad threw an open pair of sheers "too me" yesterday morning. He's not quite right anymore (85, Marine Lt. Col.). I was backed up against a ledge at the time adjusting sprinklers. Anyway, it was my hand or upper chest, so off to the doc. tomorrow for a stab wound on the palm..................But I had prior arrangements (ha!), so I tore down the bed. Today was get organized day and I cleaned up the reverse housings...........Man, the rubber on three of four pieces were a mess. I realized today it's not corrosion, or at least mine weren't. The dirt came of with oil, rubber cleaner and a wire brush on a low setting. Took some patience like most everything else, but they turned out nice.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 08-01-2016, 10:57 AM   #4054
tdangle
tdangle's Avatar
I got new shocks at each corner put on and replace the upper A-Arm bushings on the drivers side. Big improvement!
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline
Old 08-01-2016, 05:55 PM   #4055
In The Ten Ring
I bought 3M strip caulk and NAPA's version of "RTV silicon" and I've been playing around with how to get the heater box back together. Right now I await info on whether or not my rivets are the right length and I am having trouble getting the screws back into the wire-like brackets that hold the heater core over to the side.
In The Ten Ring is offline
Old 08-01-2016, 07:19 PM   #4056
matthamby
Did ya'll know the mufflers get really hot after driving around?
Got a little too close while checking the Universal Joint replacement size was correct.
matthamby is offline
Old 08-01-2016, 07:21 PM   #4057
matthamby
sorry, didn't mean to post 2x
Old 08-01-2016, 10:13 PM   #4058
In The Ten Ring
My mother burned her leg on the tailpipe of her 1975 Pontiac Bonneville badly once. Careful around hot things!
I forgot to mention earlier that I cleaned my heater motor's fan with about 100 Q tips. I couldn't get it off the motor shaft and was too afraid to force it. I cleaned it pretty well though, even used and old toothbrush.
Old 08-01-2016, 10:21 PM   #4059
In The Ten Ring
Old 08-01-2016, 11:13 PM   #4060
71CHEVYSHORTBED402
Best thing for burns I've found is aloe vera, and lots of it. I once grabbed the exhaust pipe on a rotor till. It nailed me pretty good, instant blister. I caked aloe on and the next day....nothing.
Tony
Old 08-01-2016, 11:23 PM   #4061
matthamby
I sprayed it with unburn, it doesn't hurt, I didn't get it on quick enough it had started to blister before I could get it on. Last year I was tilling up a part of my yard, the tiller quit because something caught in the tines, so I kneeled down and placed my hand on the top for balance, what was on the top? - the muffler! I heard the sizzling, and the heat on my palm, jerked my hand back to see a wet hand print sizzle away, my wife was screaming, I jumped back shaking my hand, I could feel the heat, looked at my hand and nothing, heat was going away, I couldn't believe it! I had enough sweat on my hand that it protected my hand, you talk about having a guardian angle! It took a while to get my wife calmed down.
Old 08-02-2016, 03:55 PM   #4062
dflarsen77
Active Member
Well bros I got my truck running. Got a new tank from Autozone, Spectra brand, fits like a charm. Fuel line plumbed, new fuel pressure regulator added, vent system hooked up. And I'm cruising. This is basically the first time I've been able to drive it since I drove it home in late June, and that was just an hour and a half on the freeway. Now that I drive it, the giant hole on one of the headers sounds terrible, the steering is really sloppy, and the brakes pull pretty hard left. And it was getting overheated a bit while I was putting around town, but it was 105 outside. But I've got plans for all of it! Woohoo!
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline
Old 08-02-2016, 06:21 PM   #4063
Dave K.
Dave K.'s Avatar
Ouch, love hurts
Dave K. is offline
Old 08-02-2016, 06:26 PM   #4064
RodnRudy
RodnRudy's Avatar
I spent yesterday and today doing the CLR bath treatment then used polishing compound and finally Mothers Cleaner Wax. She's ready for the Nats!
RodnRudy is offline
Old 08-02-2016, 08:21 PM   #4065
cornerstone
cornerstone's Avatar
Wow she's pretty. Congradulqtions are due! Elbow grease is not cheap but sure goes a long way!
cornerstone is offline
Old 08-03-2016, 01:22 PM   #4066
Metaldoc
Metaldoc's Avatar
New diy door panels to finish up the interior. I used license plate plastic threaded clips in the missing weld nut locations for the door panels. They fit perfect.
Metaldoc is offline
Old 08-03-2016, 01:50 PM   #4067
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Move them outside for a wash and new shoes on the blazer
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 08-03-2016, 03:46 PM   #4068
Grumpy old man
Grumpy old man's Avatar
OLD GUY TRICK ... Use toothpaste ! It relives the burning feeling immediately and speeds healing overnite . works everytime !
and when you get flash burns to your eyes when speed tack welding , cut a regular potato and squeeze the potato juice into your eye it relives the burning feeling and works better than any over the counter eye medication
Grumpy old man is offline
Old 08-03-2016, 04:26 PM   #4069
docrock
docrock's Avatar
Changed the oil
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline
Old 08-03-2016, 07:26 PM   #4070
In The Ten Ring
I reassembled my heater box. I used the RVT silicon and 3M strip caulk as suggested.
Old 08-03-2016, 07:58 PM   #4071
JG67
Originally Posted by SoCoC10 View Post
Installed some CPP lowering springs. Here is the after...
What drop did you get?
JG67 is offline
Old 08-04-2016, 06:51 PM   #4072
In The Ten Ring
I put my heater core into my reassembled heater box. I had to dispense with the rectangular gasket as I just couldn't line up the screws to the brackets with it on. As I wrested the heater core around trying to, part of the gasket can un-sealed with the heater core anyway.
I also cleaned the front of the cab where it mounts and removed all the old gasket caulk. The original paint there is very pretty!
Old 08-04-2016, 07:31 PM   #4073
Lavinia
I apologize but I can't for the life of me figure out how to post a question....so....I currently own a 1972 Chevy Cheyenne long bed truck, it came from Macon Georgia, on the tailgate the L in Chevrolet is upside down, does this give the truck more value? It looks like a factory mistake, but I am not sure. I would appreciate any help with this, thanks.
Lavinia is offline
Old 08-04-2016, 07:45 PM   #4074
Grumpy old man
I'd have to see a picture to even half way believe that .
Old 08-05-2016, 07:42 AM   #4075
Lavinia
Ok, I will take a picture....but does it make it more valuable?
Lavinia is offline
Closed Thread
