Old 08-01-2016, 05:05 PM   #1
Neutral Zone
Neutral Zone's Avatar
Passenger side headlight is dim
I have a 71 C10, the passenger side head light is half as bright as the drivers side. All the connections look ok, any ideas on a fix?
Dwain Jones
Georgetown, Texas
1971 C/10 Cheyenne 454
2016 Z51 3LT Stingray
2017 Audi A7
2008 Saab 9.3 Aero
Neutral Zone is offline   Reply With Quote
Old 08-01-2016, 05:18 PM   #2
truckster
truckster's Avatar
Re: Passenger side headlight is dim
Always check the ground first. I might look good, but 40+ years of corrosion takes a toll.
truckster is online now   Reply With Quote
Old 08-01-2016, 05:58 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Connections can look okay and still be electrically poor. Take 'em apart (or unplug them) one at a time, clean 'em, and retighten or plug back together. Dielectric grease can help reduce future corrosion. Might be a good idea to check voltages before, during, and after cleaning the connections. And it's also possible you could have full voltage and a failing headlamp.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-01-2016, 06:00 PM   #4
kwmech
A little tough being on the pass side. You'll have to move the battery out of the way to get to the ground wire. There is a black lead coming from the connector that goes to ground about 5'' away from the bulb. Loosen the bolt, clean it up and snug it back down. Should be fixed, if still dim, may actually have a bad headlamp
Old 08-01-2016, 06:22 PM   #5
In The Ten Ring
I clean all connections I can reach with sandpaper and then wipe clean. Dielectric grease eh? I'll get some for the reassembly. I have my whole front end off.
In The Ten Ring is offline   Reply With Quote
Old 08-01-2016, 06:50 PM   #6
truckster
truckster's Avatar
The grease prevents oxidation and corrosion. If you don't have dielectric grease, any heavy grease or even Vaseline will work.
Old 08-01-2016, 07:08 PM   #7
hamjet
hamjet's Avatar
try switching headlights to opposite sides to make sure its not the bulb..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 08-01-2016, 07:22 PM   #8
Neutral Zone
Thanks for the quick response guys.
Dwain Jones
Georgetown, Texas
2017 Audi A7
2008 Saab 9.3 Aero
