Old 08-04-2016, 08:46 AM   #1
old51sedan
old51sedan's Avatar
Question Top of Dash
The top of my dash, cardboard part where the defroster vents are needs attention. In all the catalogs I have I havn't seen any listed. I'm sure these were painted with a flat or matt finish in regards to the glare from the sun. Is it possible to remove it from the truck without pulling the windshield? Maybe just pulling the dash pad and inside moldings?
old51sedan is offline   Reply With Quote
Old 08-04-2016, 09:12 AM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Top of Dash
Cardboard part?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 08-04-2016, 09:15 AM   #3
snipescastle2
snipescastle2's Avatar
Talking Re: Top of Dash
wondering if he means the insulator pads on the firewall?
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 08-04-2016, 09:51 AM   #4
robs71
robs71's Avatar
Re: Top of Dash
hello old51sedan.Top off dash where defrost outlets are is metal.If yours appears to be cardboard maybe a past owner fitted a piece of material there.If you remove your dashpad you will be down to the metal that runs up to the window.a good lite sanding and a good tape job and you are good to go.....a good flat black spray will do the trick.hope there is no ugly holes under the cardboard if there is a piece of it. remember no cardboard on top of dash ever....unless previous owner installed for some reason.......satin works also..but I hate glare...little bit of glare with satin I have found......Rob..
robs71 is offline   Reply With Quote
Old 08-04-2016, 03:48 PM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Top of Dash
As said, no cardboard. dash is steel. And just to add to the conversation I painted my dash gloss body color and wet sanded the shine down, looks great, reflection but no glare. Did the same with the defrost vents.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 08-04-2016, 04:06 PM   #6
old51sedan
old51sedan's Avatar
Re: Top of Dash
Thanks for the replies. I guess it's time I tore it apart to see what is going on. I've got a new column on the way that needs painting so it sounds like a good time to do something with the top of the dash also.
