Old 06-17-2016, 05:53 PM   #1
Clavo106
anyone have a cheap cab or bed dolly set up?
My Cherry picker legs keeps hiting the dolly I made so I cant transfer my bed and cab when I need to work...its so low that the legs hit the caster dolly. I could buy new bigger casters but was wondering who has a nicer cheaper set up for this.. thanks
Clavo106 is offline   Reply With Quote
Old 08-04-2016, 07:31 PM   #2
rscar55@gmail.com
Re: anyone have a cheap cab or bed dolly set up?
I have never uploaded a photo to the site before, so i am not sure if the photo showed up. I made mine out of a set of discarded tow dolly wheels. Cut the spindles off of the Dolly's welded them to a 2X2X 3/16 angle iron. Then bought a couple of inflated tire swivel cadters from harbor freight, and welde them at the opposite end. Laid a couple of 4X4 in the angle iron frame rails. The rockers Hang over the edge. Hope that helps. If the pictures did not show correctly send me an email
rscar55@gmail.com is offline   Reply With Quote
Old 08-04-2016, 07:42 PM   #3
Grumpy old man
Grumpy old man's Avatar
build your own using 2X4's and cheap dolly wheels from harbor freight . it's not going to live there just long enough to rebuild it .
Old 08-04-2016, 08:18 PM   #4
In The Ten Ring
I would think 2x4's and some castered wheels would do it.
I built a storage cart from 1x4's and 2x4's and casters I bought from Tractor Supply last March and it has some 400 pounds of steel piled onto it and pushed under my garage counter. These cabs and beds don't really weigh that much anyway. I hear 4 men can lift and carry a cab so it cannot be too heavy.
In The Ten Ring is offline   Reply With Quote
Old 08-04-2016, 08:30 PM   #5
projectking
projectking's Avatar
I have a 2x4 one I built to roll/work on a bed that's held up fine.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 08-04-2016, 08:40 PM   #6
franken
I seem to recall someone was selling plans to make one from exhaust tubing that allowed you to roll it so the cab was in the normal position, or so the bottom was to the side to work on the underside. If that made any sense at all...
Picture two lengths of tubing making an L shape with the corner rolled by the muffler shop bolted to the cab mounts. Add features as desired.
Old 08-04-2016, 11:16 PM   #7
seafoam68
seafoam68's Avatar
Made mine out of two by fours and cheap caster wheels. Made the cab one so the front and rear two bys lined up with the cab mounting bolt holes so I could run the bolts down into two bys to keep it steady. You can build stout enough to use on multiple projects. Just do a little measuring and make a trip to the lumber store.
seafoam68 is offline   Reply With Quote
Old 08-04-2016, 11:18 PM   #8
seafoam68
seafoam68's Avatar
Franken, I remember seeing that as well. Thatwas the trick for working on the bottom. Maybe it is here in the search?
Old 08-04-2016, 11:33 PM   #9
Warrens69GMC
Warrens69GMC's Avatar
here
http://67-72chevytrucks.com/vboard/s...d.php?t=192185
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-05-2016, 02:32 AM   #10
Dustmaker65
Dustmaker65's Avatar
Here is a couple pics of the one I use... one with my helper
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 08-05-2016, 09:25 AM   #11
Snapper24
Had same problem with one I made out of 2x4 s, my hoist legs were too high, just took casters off, cut some 2x4 PCs and lag bolted them where casters mount problem solved.
Snapper24 is offline   Reply With Quote
Old 08-05-2016, 01:31 PM   #12
tommys72
tommys72's Avatar
You have some measurements of that thing dustmaker?
The dolly, not your helper....im getting ready to build one for myself
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-05-2016, 07:21 PM   #13
otsenre
otsenre's Avatar
I made mine out off a truck frame and used scaffold casters, used it alot as I used to part alot of these trucks. Check it out Name:  IMG_0720.JPG
otsenre is offline   Reply With Quote
Old 08-05-2016, 07:33 PM   #14
franken
Originally Posted by Warrens69GMC View Post
So much for my remembering it as bent tubing...
Old 08-05-2016, 07:44 PM   #15
Dustmaker65
Outside measurements are 37 x 48...
Now for my helper....better stick with dolly
Jimmy Hoelzel
Old 08-05-2016, 11:23 PM   #16
Metaldoc
Metaldoc's Avatar
two pieces of pipe, four wheels. It rolls nose to back.
Metaldoc is offline   Reply With Quote
Old 08-06-2016, 10:32 AM   #17
slikside
slikside's Avatar
^^^^^^^^^^Pretty Slik^^^^^^^^^^^^
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 08-06-2016, 09:28 PM   #18
seafoam68
seafoam68's Avatar
I say metaldoc wins! Lol
Old 08-06-2016, 11:59 PM   #19
Metaldoc
Metaldoc's Avatar
I could roll it my self with some effort but not impossible. If ya lived closer I'd say come borrow them as they are not needed till next time.
Old 08-07-2016, 12:05 AM   #20
Warrens69GMC
What diameter pipe and did you bend it yourself?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-07-2016, 02:18 AM   #21
Clavo106
WOW. I Was not inspecting a response on this thread.. lots of love here.. I made mine like dustmaker65. Bigger casters are need..on mine. But metaldoc is there a cross member brace on that dolly im interested?
Old 08-07-2016, 08:05 AM   #22
Metaldoc
Metaldoc's Avatar
pipes are 1/8 wall and 2inch dia. no cross brace but could of needed one. I took the pipes to a muffler shop to bend them.
Old 08-07-2016, 10:09 AM   #23
Dustmaker65
You have pics without a cab on it?
Jimmy Hoelzel
Old 08-07-2016, 04:41 PM   #24
Metaldoc
Metaldoc's Avatar
I hope these help I can take more pics or dimensions. Vertical tube is 48" as well high.
