Closed Thread
Old 07-31-2016, 11:31 PM   #2451
66Submarine
66Submarine's Avatar
Re: What did you do to your truck today part III
Killed it?
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline
Old 07-31-2016, 11:38 PM   #2452
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by 66Submarine View Post
Killed it?
Blew a freeze plug. lol And ended up pulling the dang motor because it needed new front and real main seals and new gaskets anyhow. SO I have a new gasket set coming and will take the engine apart and clean all the sludge out and reseal and repaint. Oh, Here is a picture of the clutch and pressure plate. They look fine right?
TJ's Chevy is offline
Old 08-01-2016, 03:45 PM   #2453
forestb
forestb's Avatar
Started varnishing my bed wood on Saturday. It started to bubble a little at the surface. Thinking it is because of heat. Will nock it down with some steel wool and give it another coat.
forestb is offline
Old 08-02-2016, 09:40 PM   #2454
TJ's Chevy
TJ's Chevy's Avatar
Started painting the 305 v6. Got the oil pan, valley pan, and motor mounts painted up. Waiting on parts so I am gettin her perrtied up.
Old 08-06-2016, 12:26 AM   #2455
TJ's Chevy
TJ's Chevy's Avatar
Getting more done. Valve covers came out better than expected.
Old 08-06-2016, 09:33 AM   #2456
Jdm63
Finished up steering - thanks again Captainfab for the adapter plate
Jdm63 is offline
Old 08-06-2016, 09:49 AM   #2457
karlbenz
got my speedometer cable put in. napa #bk6151606
New wiper arms and blades from oreilys. ya gotta get the "classic" blades
got the material cut for the new gas tank. looking forward to freeing up the space behind my seat
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is online now
Old 08-06-2016, 09:53 AM   #2458
karlbenz
Originally Posted by Hugh in NC View Post
Project Fix-a-Leak.
Radiator started leaking around the top seam. The radiator did not look to be in the best condition so I replaced it with an American Eagle 2 row with 1 inch tubes.
I got the same radiator. works great so far. found out later that american eagle is another name for champion which has excellent reviews
1965 Chevy C60
Old 08-08-2016, 10:57 AM   #2459
TJ's Chevy
TJ's Chevy's Avatar
Yesterday evening:
Old 08-08-2016, 08:06 PM   #2460
Hugh in NC
Hugh in NC's Avatar
American Eagle is the premium version of Champion. It has larger 1 inch tubes.
Champion 2 row has .75 inch tubes.
Hugh in NC is offline
Old 08-09-2016, 12:26 PM   #2461
Narxoleptic Customs
Bought a power steering conversion bracket!
Narxoleptic Customs is offline
Old 08-09-2016, 07:46 PM   #2462
NVS-C10
NVS-C10's Avatar
I finally finished up the wood door to cover the air bag setup and topped it off with a bottle cap opener to use as a handle in opening the door.. it also doubles as the perfect tailgating accessory!
NVS-C10 is offline
Old 08-10-2016, 04:23 PM   #2463
forestb
forestb's Avatar
got it back from paint
forestb is offline
Old 08-10-2016, 06:01 PM   #2464
LVPhotos
LVPhotos's Avatar
Poked a 2"x2" hole to use the new shifter.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 08-11-2016, 08:14 AM   #2465
karlbenz
yep, thats why I went with that one
Where bouts are you in NC?
1965 Chevy C60
Old 08-11-2016, 04:41 PM   #2466
karlbenz
Finally got my tank built and installed. 30 gallon. I think my fuel gauge is bad? Stays pegged at full
1965 Chevy C60
Old 08-11-2016, 05:10 PM   #2467
goatless
goatless's Avatar
Is this just stained plywood? Looks great, whatever it is! I'd like to duplicate.
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline
Old 08-15-2016, 04:57 PM   #2468
NVS-C10
NVS-C10's Avatar
The bed is made up of "common wood" boards from Home Depot that have been stained and sealed with Olympic Maximum stain and sealant in one. The door over the airbag system is plywood with the same stain/sealer.
Thanks!
NVS-C10 is offline
Old 08-15-2016, 05:59 PM   #2469
The Rocknrod
Moderator
The Rocknrod's Avatar
Got the rear end mounted on the trailing arms and on jack stands - Shhhhhhh (don't tell the wife) I'm not supposed to be working on the truck yet (I'm in post op recovery).
The Rocknrod is offline
Old 08-31-2016, 12:29 PM   #2470
Northwest Outlaw
Northwest Outlaw's Avatar
I was able to score a Lokar shifter for my th400 on Craiglist, with a set of shorty header (unused) for $75 total!! The shifter didn't have the mount hardware or linkage, so...
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline
Old 08-31-2016, 01:16 PM   #2471
RKS0069
RKS0069's Avatar
Hi. Finally started back up a month ago and I'm making okay progress. I quit my job in order to work on this truck full time. Moving to Oregon soon!
http://67-72chevytrucks.com/vboard/s...d.php?t=675881
1972 C-10 SWB
1962 3/4 ton LWB
2011 GMC Sierra LML Z71 crewcab shortbed
RKS0069 is offline
Old 08-31-2016, 05:42 PM   #2472
canadian_diesel1964
Micro buck build looking like a truck again...
canadian_diesel1964 is offline
Old 08-31-2016, 05:55 PM   #2473
Figuarus
Figuarus's Avatar
RKS, what are those tanks? you have a build page on what you're doing there?
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline
Old 08-31-2016, 07:11 PM   #2474
RKS0069
RKS0069's Avatar
Tanks are from LMC
1972 C-10 SWB
1962 3/4 ton LWB
RKS0069 is offline
Old 09-04-2016, 03:36 PM   #2475
chevy2tom
chevy2tom's Avatar
Painted black behind the grill, white around the eyebrow, new chrome bumper, grill & bezels plus it's my new wallpaper on my phone
chevy2tom is offline
Closed Thread
