Factory Tach Won't Work
I had my truck together a few years ago and the tach worked fine. After a few years of sitting, my tach won't work. I have a painless wiring kit and a built 400 small block with a pertronix HEI. Everything appears to be hooked up fine. Is there anything simple I may be missing. It's possible someone may have took something apart and didn't put it back correctly. The wiring diagram has the purple/white wire going from the distributor to the tach. And I also have a yellow wire plugged into the tach. Does anyone have any ideas?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
![]() Join Date: Nov 2012
Re: Factory Tach Won't Work
Mine also stopped working mysteriously. I simply removed it from the truck and sent it to these people.
Willcox Corvette, Inc. 123 E. Maple Street*Jeffersonville,*indiana*47130* 800-588-3883 You may have to call and make sure they are willing to fix it. They typically work on Corvettes mostly, but occasionally they will work on these truck tachs as well. They are very friendly and very fast too. I got mine back in less than a week.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
Mine also did not work with a Pertronix module in a stock body distributor. So I swapped it for a repro that a friend had and that works, so it was hit or miss. I do know with the Pertronix the low-RPM reporting can be off because it does multiple spark, sometimes that will skew it to read higher than actual.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
I just put a factory tach into my 69 CST-10... It's supposed to ground to the cluster tin but mine wasn't. I ran another ground from a screw under the dash and up to the grounding lug on the tach and mine started working. Maybe checking your grounds and cleaning them up might help.
1969 CST/10 "GreenAndWhite" 1974 Nova (SOLD... End of an Era) 2000 Impala (RIP) 2008 Malibu Brand Loyal... I've never owned a Vehicle not made by Chevrolet. |
