08-08-2016, 12:37 PM | #1 |
Fuse Block "Pins" ??
With short of buying a complete under dash harness can the fuse block be re-conditioned?
Can the in my words the "pins" that hold the Glass Fuses in place and the Straight Blade connectors that use the Push in Wire Housing Plugs be replaced or would that be Only a Complete unit exchange thing? The picture here I have circled what my question is all about. Thanks in advance. |
08-08-2016, 12:38 PM | #2 |
Re: Fuse Block "Pins" ??
Each of those is actually a terminal on the end of the wire, so yes, they can be replaced. I have a bunch of spare harnesses I would pirate them from, but you can likely buy them new as well and crimp-solder them on. Then they just stick into the big black plastic block that forms the fusebox and you're done.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-08-2016, 01:07 PM | #3 |
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
08-08-2016, 01:07 PM | #4 |
08-08-2016, 04:38 PM | #5 | |
08-08-2016, 10:45 PM | #6 | |
The Older Generation
LockDoc
08-09-2016, 08:42 PM | #7 |
I took some out of an old harness and I pretty much cracked/chipped the Bakelite fuse box getting them out. So, be careful in prying those puppies out, it's not that easy. If you do manage to get them out, try head blasting them with fine glass beads....works pretty good, you could always use a media tumbler to do the job as well.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
08-10-2016, 12:27 AM | #8 | |
Thanks Ben |
08-10-2016, 12:50 AM | #9 | |
08-10-2016, 03:05 AM | #10 |
That's NOT what I am after. What I want to do is re build the Fuse Block pins or glass fuse holders that are Originally installed in the fuse block.
08-10-2016, 07:53 AM | #11 |
You might try masking the face of the fuse block with "painters tape" then head blasting the terminals lightly, I wouldn't dwell in that area very long though.
Ben
08-10-2016, 08:28 AM | #12 |
Sorry, that should have read "bead blast" dang auto correct.....
Ben
08-10-2016, 10:56 AM | #13 |
Yah I also thought of doing something like that. I have a small hand held blaster that does & can use soda blasting media & I do have different sizes/grit of media so I guess I'd do a little experimenting with the different grits of media probably sticking with the Soda. thanks
08-10-2016, 04:39 PM | #14 | |
LockDoc
08-10-2016, 05:47 PM | #15 | |
08-10-2016, 10:07 PM | #16 | |
LockDoc
