08-08-2016, 05:42 AM | #26 |
Re: 54 chevy truck fitting front fenders
I'm over whelmed.The truck will not be done in time for the car show in The Dalles this weekend ,but i can still drive it there
08-08-2016, 05:44 AM | #27 |
And thanks for all your help.I thought retirement was going to be easy
08-08-2016, 10:05 AM | #28 |
There are a lot of quick fixes, this is not one of them! You are going to have to have a dance with that front end, learning every step to "You should be dancing" isn't going to be easy, I have tried!
https://www.youtube.com/watch?v=4yAkkpbm_8E Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
08-10-2016, 05:00 AM | #29 |
After all the excalent advice that I recived here this is what I did.First I relized the front of the fenders don't move up and down,had to move hood.I took hinges off the hood and removed the latch pin,from there it was easy to get the hood right where I wanted it,closing the rear gap to about an 1/8 inch tightened the bolts and it was good,still need to lift rear of fenders a little but I have room to do that
08-10-2016, 05:23 AM | #30 |
I wanted to say I removed the hood springs,not hinges
08-10-2016, 05:43 PM | #31 |
That is a simple yet profound bit of advice.
1951 Chevy Panel Truck |
08-10-2016, 06:35 PM | #32 |
The fenders do move up and down. There is room at the back with the giant holes in the cab, and by moving the rad support up and down.
Brian
08-11-2016, 01:27 PM | #33 |
After fighting several truck front ends trying to figure out a way to " cheat it" or adjust what had been installed by someone else, I finally take this approach and has worked every time, but takes a couple guys, lots of masking tape to protect paint edges etc.
Pull everything apart, core support, radiator, struts, fenders and hood. Align hood to cowl, level etc first. Install core support loosely Install fenders and align them to hood, some adjustments ( elongating holes) might be necessary. This takes an entire day with 2 guys. It's tedious but works
GOD BLESS AMERICA! |
08-12-2016, 08:33 PM | #34 |
Friend of mine who has been doing these trucks for years, swears that the best method is to assemble the front clip, then put that on the truck. Did that with my 55 sedan and will try it on the 50 3100 as it worked well on the 55
08-12-2016, 08:47 PM | #35 |
Hollister Road Co.
from the pictures I've seen from GM this is how they did it at the factory. Its usually easier piece by piece if you don't have help
