![]() Join Date: Feb 2010
Re: Top 5 performance mods that won't blow my motor.
1 HP/cubic inch is fairly doable with your 5 mods request.
1 - Headers 2 - Cam 3 - Intake 4 - Carb 5 - Decent ignition For the numbers you want you might consider a off the shelf motor. By the time your do all the machine work and parts to rebuild yours you might be money ahead to buy a ready to go engine.
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find) 67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find) Keith Riel |
Okay. That does make sense. That was sorta along the lines I was thinking of. Thanks cat.
Good cylinder heads are important. praisegeetarman 1 HP per cubic inch would only be 327 HP. I do agree a crate engine would probably his best option
Boyd -67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie ![]() |
I will tell you first hand you'll be dumping some serious cash. I just built a 331 (327 bored .030 over) for my 65 Nova gasser. I started with a tired block, did machining, went with full rollers (cam, rockers, lifter), tunnel ram with dual quads, edelbrock performer rpm heads, plus all the accessories and I'm pushing about 500 hp. But I will tell you that my cost for parts and machining (as I did the assembly myself) was close to $5,000. Yes my Nova will run low 10's in the 1/4 mile and redline at 7,500 rpm...but going fast costs money period.
Customization is what you want it to look like -- not what other people think it should look like |
#5 | |
I changed his up a little but right idea.
