Old 08-13-2016, 01:22 PM   #1
Smokintire70
Gear ratio in transmission. Explain please.
I don't know how the gear ratio works in a transmission. Can some one explain it to me like I'm im kindergarten? That would be great. Thanks.
Smokintire70 is offline   Reply With Quote
Old 08-13-2016, 01:55 PM   #2
Alex V.
Alex V.'s Avatar
Re: Gear ratio in transmission. Explain please.
The changing of ratios, or how each ratio relates to engine RPM, ground speed, etc.? More specifically, automatic or manual?
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 08-13-2016, 02:21 PM   #3
davepl
davepl's Avatar
Its like your old ten speed bike, but instead of big gears and little gears connected by a chain, it's big gears and little gears meshed together directly. In lower gears the engine can produce more axle torque but at lower speeds, good for climbing hills and pulling boats. At higher speeds that gear reduction goes away until in high gear it's 1:1 (in our trucks) and the rear end is the only gear reduction between piston and tire.
Since you can't stop the wheels while the engine is running, the torque converter allows some slip between the engine and the trans when they two are turning slowly, and then less and less slip as they turn faster, up to about 1500 rpm when there's almost no slip.
Old Powerglides only have 2 gears. Most of our automatics in these trucks are 3 speeds. Later models have 4 or 6 or even 10 speeds these days.
Basic enough? Need more detail?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-13-2016, 03:43 PM   #4
Smokintire70
It's a 700R4. So the first gear is 3.06. Does this mean the output of the transmission is basically 1/3 of the engine speed? And 3rd gear is 1.00, meaning the engine speed is equal to output speed of tranny? Also the 700R4's overdrive is .70 so the tranny output spins faster than the engine speed. Is this all correct?
Old 08-13-2016, 04:40 PM   #5
Bigdav160
Bigdav160's Avatar
Yes!
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-13-2016, 05:20 PM   #6
Smokintire70
Cool thank you guys! It was kinda confusing to me. Glad I got it.
Old 08-13-2016, 05:20 PM   #7
davepl
davepl's Avatar
It is. Also on these later model units there is a clutch that can lock up so that the torque converter doesn't slip -at all- once rolling along at a good speed in top gear, for example.
