Old 03-16-2004, 11:20 PM   #1
72afr
Beep! Beep!
72afr's Avatar
Brake Booster Color?
does anyone have any recommendations on the color that i should make the brake booster. i have a red truck with a flat black firewall and gloss black fender wells.
thanks for any responses
72afr
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport
2003 Chevrolet 2500HD CC 6.0 4wd
2004 Jeep Rubicon some aftermarket stuff...
2019 Jeep Unlimited Rubicon (the wife's baby hauler)
72afr is offline   Reply With Quote
Old 03-16-2004, 11:51 PM   #2
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
I vote black
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 03-17-2004, 12:26 AM   #3
Low69CST
I bought a nickle cad kit from eastwood, it looks crappy, not the new look like a brand new booster, i vote flat black or cast iron
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 03-17-2004, 12:31 AM   #4
72afr
Beep! Beep!
72afr's Avatar
thanks, i forgot about the master cylinder, any ideas?
Old 03-17-2004, 12:33 AM   #5
Low69CST
we paint ours cast iron as well
Old 03-17-2004, 12:44 AM   #6
72afr
Beep! Beep!
72afr's Avatar
thanks, sounds like ill go with cast iron
Old 03-17-2004, 03:38 AM   #7
Sweet72
Sweet72's Avatar
Delco Morraine boosters were cadmium plated from factory and Bendix units were painted black. MC's of course were cast iron.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 03-17-2004, 08:42 AM   #8
Blue Beard
Blue Beard's Avatar
What's the best way to clean them before painting.........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-17-2004, 12:07 PM   #9
72afr
Beep! Beep!
72afr's Avatar
i second that question
Old 03-17-2004, 12:20 PM   #10
ljbear
ljbear's Avatar
I taped up all the ports then blasted it with glass beads. Leaves a pefect base for primer and paint.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 03-18-2004, 02:28 AM   #11
Low69CST
we put a wire brush on an angle grinder
