08-08-2016, 06:52 PM | #1 |
toolbox door screw sizes
Could someone please advise what size the screws are supposed to be for the toolbox door hinges? I need to drill out and re-tap the holes in the door. Also is the fiberglass box just held in by sheet metal screws? if so what size?
Thank you
Tim 1971 C10 Cheyenne 350/350 |
08-14-2016, 08:31 PM | #2 |
Re: toolbox door screw sizes
ttt anyone???
08-14-2016, 08:43 PM | #3 |
Can't help with the tool box door hinge screw size but the fiberglass box is also supported at the back of the box under the bed floor. Believe they are 1/4 x 20 Phillips head, about 3/4'' long thru the bed floor down into a double L bracket that uses the same type screws thru the back of the fiberglass box. The double L bracket also has a doubler plate for reinforcement.
Have pulled a couple tool box setups from parted trucks and that is what I found on all of them. Wish my '71 4x4 had the tool box setup but then it would have been more $$ to fix the rust and then a decent door and a good fiberglass box and a good set of hinges and a good L bracket and ........... sometimes seems never ending. Hope that helps some.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
