Old 01-12-2016, 10:20 AM   #26
rtinniste
Re: 49, bagged, 6.0, patina, the works
What I ended up with at the end of that night
[IMG][/IMG]
And back on the ground again. Dad had some random old radials laying in the basement which were good to get the chassis back on the ground and size up how it will lay.
[IMG][/IMG]
Nice build reminds me alot of mine except I'm using thor bros 4 link (gotta love how nice Jason's kit lines up definitely worth the wait) and i fabbed my own cab mounts, the code504 kit looks super nice takes alot of guess work and fab hours out of it. Honestly makes me think about just going that route instead of buying a new welder.
But front control arms I'm not sure how it is with the 6.0l but I heard stock uppers hit exhaust manifolds with a small block. Speedway has tubulars for $50 bucks an arm just get 2 left sides because they are for circle track cars.
But i have to ask any info on the vw in the back ground??
rtinniste is offline   Reply With Quote
Old 01-12-2016, 10:59 AM   #27
reaper71
reaper71's Avatar
Cool build,nice work...I'm In..
Mark...
reaper71 is offline   Reply With Quote
Old 01-13-2016, 08:54 PM   #28
84blaze
Originally Posted by NickL View Post
I just got them in the mail yesterday so I'll take some detailed shots soon. Engine should be sitting between the frame rails soon.
Just been so busy working, sorry for the lack of updates everyone!
Thanks for the photos man. I appreciate it.
Its too bad the truck oil pan doesn't fit as is. I did a Holley pan on my Blazer 6.0L swap and didn't want to shell out that kind of money again. Hopefully an H3 pan or something else cheap will work.
84blaze is offline   Reply With Quote
Old 01-18-2016, 12:16 PM   #29
NickL
The code504 kit is great and I bought it for that exact reason, just being able to take the guesswork out of things. I'm expecting them to probably hit but that was my exact plan if they did!
The mk1 is actually g60 supercharged swapped, cool little car and fun. Was a friend of mines who I no longer share a shop with.
NickL is offline   Reply With Quote
Old 01-21-2016, 08:32 PM   #30
84blaze
the truck oil pan has way too much depth to it and is preventing the frame from airing out all the way.
How far does it hang below the front k member with those mounts?
I'm considering one of those H3 pans if it's less than 1 1/4 inch.
Chevrolet Performance Musclecar Oil Pan Kits 19212593
Here are some measurements of LS Pans for you to compare.
LS engine oil pans - all of them
Old 02-02-2016, 12:55 AM   #31
NickL
Ill take a measurement but I believe its around 3". The F-Body pan will solve my issue according to that site.
Been working on other projects lately but took some time today it modify the trans crossmember to clear the pan of the 4L80e
Old 02-18-2016, 08:40 PM   #32
HULK64
Do the motor mounts that come with the 504 kit work with the LS motor?
HULK64 is offline   Reply With Quote
Old 05-21-2016, 08:24 PM   #33
NickL
They may give you the option now, but the ones included with my kit when I bought it were for a SBC.
Old 05-22-2016, 10:40 AM   #34
NickL
Started working on repairing the running board mounts. My idea behind this was to keep it simple, functional, structurally sound and not affect the patina on the front side of the board.
What I started with:
In process
Test fit
Now to just coat the underside and should be good. Moving on to the other side, then rear suspension.
Old 06-28-2016, 10:31 AM   #35
booney
Cool build. I seem to be having a bit of trouble seeing all of the pics in this thread. Maybe something on my end? Can everyone else see all of them? Thanks.
booney is offline   Reply With Quote
Old 06-28-2016, 11:11 AM   #36
NickL
Seems like some of them have disappeared. I really hate photobucket for reasons like this. The others seem to be working fine though, ill have to see what I can do about the missing ones.
Old 06-28-2016, 11:14 AM   #37
mongocanfly
mongocanfly's Avatar
Booney I have the same trouble with seeing pics on some builds..some are no trouble though..
Old 06-28-2016, 02:43 PM   #38
booney
Thanks Nik. I wouldn't bother you about it but, What you are doing is kinda exactly what I have in mind for my son's 54 5 window.
Old 06-29-2016, 09:04 AM   #39
SalvagedSouls
SalvagedSouls's Avatar
I'll tag along. I purchased a 504 kit late last year but....it's still in boxes. Been trying to wrap up my pole barn/shop to begin working on a couple projects.
How well did everything bolt up? Any modifications needed?
-Jonathan-
1949 - 3600 Update suspension, engine and drive it.
http://67-72chevytrucks.com/vboard/s...d.php?t=691034
1953 - 3100
1955.1 - 3100 Bare Metal Build
http://67-72chevytrucks.com/vboard/s...d.php?t=691261
1965 - Buick Special & 1965 Buick Skylark
SalvagedSouls is offline   Reply With Quote
Old 08-10-2016, 09:12 AM   #40
NickL
Going to host all my photos in a different spot now so shouldn't have any problems now. Awesome build between you and your son!
-Jonathan-
Everything bolted up great. Upon first test fit the cab everything was pretty much spot on.
Some progress:
Notch in. Calculated for the larger tire I want to run as these are just rollers.
Motor/trans sealed up/painted and back in. Frame lays perfect with some weight over the 2600's. Once the bed is on all should be well.
Bridge/bag mounts tacked in
Still learning a lot about welding, anyone have any criticism here? Always looking for tips on how to get better.
Old 08-10-2016, 09:03 PM   #41
Advanced Design
Advanced Design's Avatar
Chassis is looking good...awesome welds!
Advanced Design is offline   Reply With Quote
Old 08-10-2016, 09:30 PM   #42
mongocanfly
Hard to criticize those welds ..they look good..
Old 08-17-2016, 08:45 AM   #43
NickL
Thanks guys. Some more updates:
Cab back on to see how the drivetrain fits. Had to cut just a small amount out of cab to fit the 4l80e. Minimal minimal tunnel work which is nice.
Had to throw a fender on of course!
Bed back on. Stoked on my measurements for the notch and bridge as the bed depth came out exactly how I wanted it. The truck will lay hard even with a bigger tire and still have plenty of room for a usable bed.
Next is to brace the bed up and replace the rusty rear crossmember. I plan to roll the truck out today as a whole and break out the DSLR. First time it will see sun as a roller in 3 years haha.
Old 08-17-2016, 12:00 PM   #44
HUSSEY
HUSSEY's Avatar
Really digging this build. I look forward to hearing how your Thorbros rear link comes out. From the pics they look stout and really well made. On their website they talk about the new crossmember raising the gas tank, is that true?
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 08-17-2016, 12:08 PM   #45
NickL
The link installed really easily and seems to work great from cycling the frame up and down. As far as raising the gas tank, yes it does. Im going to run a cell in this truck but I know the S10 guys love the crossmember for that reason.
Old 08-17-2016, 04:55 PM   #46
Mains52
This thing is looking good. almost makes me want to just buy the code 504 kit.
Mains52 is offline   Reply With Quote
Old 08-17-2016, 11:22 PM   #47
NickL
Thanks man. I would definitely recommend it and their customer service is great. Im going to be utilizing a few more things from them as well.
Had some time today and decided to go through the rear end. The carrier and everything seemed to be in really great shape. No excessive wear or anything noticeable. Went ahead and replaced the wheel seals and bearings along with the pinion seal which was noticeably leaking. Sealed it back up with a fresh gasket for the rear cover, fresh fluid and assembled. Left the backing plates off in preparation for the little shop mfg rear disc brake kit I'll be ordering here shortly.
Love how its starting to come together
The next thing I want to tackle is the steering. Can anyone with the S10 swap chime in on their steering setup? I think I'm going to order Silverstarcustoms' no notch tie rods and it should do the trick. Open to suggestions though.
Old 08-18-2016, 12:09 AM   #48
mongocanfly
I really like the patina on that truck..and the black wheels make it look sinister..looking good..
Old 08-18-2016, 09:48 PM   #49
NickL
I fell in love with the patina as soon as I saw it. Thanks man!
Rolled it outside for some good pictures finally. Cab needs to come back about 1" but feels good to see it outside for the first time in 2.5 years.
Spent the rest of the day removing everything from the interior of the cab. Sound deadening on the firewall was hours of fun with a putty knife haha.
Old 08-19-2016, 10:35 PM   #50
BlueJeep
BlueJeep's Avatar
Looks fantastic!
Is that a garage, with a lift, under a house? How tall is the ceiling?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
