Old 08-17-2016, 08:54 PM   #1
30 a truck
30 a truck's Avatar
Cab mounts
I placed my bed on tonight. My cab needs to go up 1/2" for the body lines to match up. I have new rubber mounts. The bracket has not been replaced. It is in good shape. I do not have them tightened down too much, so they are not squeezed, probably needs to be tighter. Any thoughts??
30 a truck is offline   Reply With Quote
Old 08-18-2016, 10:16 AM   #2
30 a truck
30 a truck's Avatar
Re: Cab mounts
Am I the only one that has ever seen this?
Old 08-18-2016, 10:47 AM   #3
Dorchesters 72 C20
Dorchesters 72 C20's Avatar
Re: Cab mounts
Like a fat girl doing the mambo, my '72's cab also squatted with original cab rubber bushings, see pic.
I bought a kit of cab bushings, polyeurathane type, and they brought the cab back in line with the bed using original frame mounts. It was fairly easy to add an extra washer or two to help space any differences you end up with, if your bolts aren't too far gone.
Dorchesters 72 C20 is offline   Reply With Quote
Old 08-18-2016, 11:22 AM   #4
30 a truck
30 a truck's Avatar
Re: Cab mounts
Everything is new. Still 1/2" low.
Old 08-18-2016, 12:58 PM   #5
RodnRudy
RodnRudy's Avatar
Re: Cab mounts
If memory serves me I think the front and rear rubbers are different heights. Possibly in the wrong location?
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 08-18-2016, 01:17 PM   #6
kxmotox247
kxmotox247's Avatar
Re: Cab mounts
Steel bed floors sit right on the frame mounts. Wood bed floors have cushions. So as long as you're not doing something wrong there then you'll need to shim the cab up. Double check to make sure you have the mounts in the right spots like mentioned.
kxmotox247 is offline   Reply With Quote
Old 08-18-2016, 09:40 PM   #7
30 a truck
30 a truck's Avatar
Re: Cab mounts
When I shim, I assume that I shim cab & radiator support all the same amount?????
Old 08-18-2016, 10:11 PM   #8
kxmotox247
kxmotox247's Avatar
Re: Cab mounts
Is it an even 1/2" down on both sides? I wouldn't say it's a guarantee you have to shim the core support up the same amount but probably some. Is the body line across the back of the cab parallel to the front bed panel? What if you shim the back of the bed up? If the bed bolts are loose I would try just quickly putting shims in the back so the bed is slightly raked.
This is a nasty game. I spent a lot of time making mine match as well. I even contemplated cutting the bed mounts. Once the truck was mocked up, I made locating tools to precisely position everything back once I took it apart for paint.
Old 08-18-2016, 10:13 PM   #9
davischevy
davischevy's Avatar
Re: Cab mounts
Loosen all cab mounts. Starting with the rear of the cab,shim to where you want it then move to the front of cab, shim, then to core support.
Don't be surprised if you have to use more shims on one mount than the other to get doors and fenders to align.
It can be a frustrating exercise,
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
