04-03-2002, 11:48 AM | #1 |
72 Cheyenne
Starving for fuel at high speeds
I can tell I'm not getting enough fuel on the Highway, when I put it to the floor when I'm going 65-70 it hesitates for a second, I'm using a 1406 600, everything looks good, filter is new, lines are good, pump is new, any ideas?
------------------ 72 Cheyenne C20 Built 350/T350 AC/PS/PB/AT San Diego, CA Pics of My Truck <A HREF="http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src= ph&.last=1" TARGET=_blank>http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src= ph&.last=1</A> |
04-03-2002, 12:51 PM | #2 |
i had the same problem when i first built my motor and was runnin a 600 edel. i swapped that out for a 750 edel and problem solved.what all is done to ur motor
------------------ 72 chevy lwb 350 lunati cam ported and polished cast 2.02 heads proform hei edelbrock performer rpm and 750 carb balanced bottom end 9.5:1 compression ps,pb th350 with a tci 2500 stall convertor full man v-body kevlar clutches and bands as well as other goodies
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
04-03-2002, 01:32 PM | #3 |
Half a bubble off!
No help on this subject, but I just wondered if you had any luck on your grill situation yet?
------------------[*]'71 Cheyenne, 402BB[*]Winfield, KS[*] http://barn9.freeservers.com[*] steer50@hotmail.com
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
04-03-2002, 01:38 PM | #4 |
72 Cheyenne
I just put a rebuilt in, I think going to a 750 will help.
Deadman finaly responded belive it or not, he told me the Grille was on the way and should be here this week, I'll let you guys know. ------------------ 72 Cheyenne C20 Built 350/T350 AC/PS/PB/AT San Diego, CA Pics of My Truck <A HREF="http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src= ph&.last=1" TARGET=_blank>http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src= ph&.last=1</A> |
04-03-2002, 03:08 PM | #5 |
dion, try the carb jetting kit for that 1406. I had the same symptoms when I had that carb set to lean. I would try to richen it before you decide to slap a bigger carb on the engine.
------------------ Check out other members trucks 1968 50th Anniversary C-10 Suburban (Tows all these cars all over the place) 1968 50th Anniversary C-10 Pickup 1968 50th Anniversary C-20 Pickup CST 1969 SS Camaro Conv't 2000 Chevy Malibu (Suppose to be daily driver, but the Burb is) Phoenix, AZ. Click Here for Parts and Venicles I have Available THINGS I AM LOOKING FOR: 67-68 SUBURBAN TRIM. $$$$ Reward for finding the 3rd door trim piece and the small piece that goes on the 1/4 panel right behind the 3rd door.
Just sitting here contemplating contemplation. |
04-03-2002, 03:13 PM | #6 |
How do you know your problem is fuel? Couldn't it be air?
------------------ '69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed! '69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast). Seattle, WA. *See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
04-03-2002, 03:37 PM | #7 |
72 Cheyenne
Hmm.. I'll check it out, thanks.
