Old 08-20-2016, 04:27 PM   #1
CG
BlahBlahBlah
New door panel install, simple ... not!
So I got Grumpy to sew me up some nice black door panels for my 68 GMC. The old ones were kinda beat up and tan. I actually put them on quite awhile ago, but I didn't have the black estuchens or the black arm rest/pulls.
Got me some NOS estuchens and some repro counterparts arm rests. The screws that hold in the bottom of the door panels were really rusty and I ended up breaking off the bolt parts they thread in to. Not really a big deal, I think heavy duty Velcro will work fine, no screw heads to look at. I just let them hang loose at the bottom when I put them in.
Went to Lowes today and got 10 feet of heavy duty indoor outdoor Velcro. Cleaned the doors and panels with alky, lined it all up and stuck em on. Popped on estuchens, window crank and door handle. So far easy peasy.
Opened up the new arm rests, oh nice they come with new screws. Little longer than OEM because of how they are built. Go to put them on, new screw would only go in a few threads. Took em off, squirted some WD in there, still no go. Tried the old screws without the are rest, no problem. Tried the new screws, no go. Threads look the same but I guess they just aren't. In the process of doing all this I twisted off one of the bolts the arm rest screws thread in to. I guess its in the bottom of the door somewhere. My arm wont go in there so Ill never know. Not really sure how to deal with this, nothing to screw in to now. Probably something at Lowes I can figure out how to make work.
But after an hour of monkeying around with what I thought would be a simple project. I locked up my truck with all the junk just laying inside. Maybe Ill look at it tomorrow. Why is it we like messing with this old stuff?
Old 08-20-2016, 04:42 PM   #2
gable74
gable74's Avatar
Re: New door panel install, simple ... not!
Been there, that stinks. Just a suggestion but I have a flexible magnet pen for dropped screws, assuming the screw wasn't aluminum or stainless . Its about 18" long and can get into some pretty tight spots. Its like $5 at harbor Freight. Should pull that screw right out of there so no rattles.
1972 K-20 Custom Camper
1971 K2500 Custom Camper (Sold)
2014 GMC 2500HD DMAX
gable74 is offline   Reply With Quote
Old 08-20-2016, 05:05 PM   #3
CG
BlahBlahBlah
Haha, I was so frustrated over probably one of the simplest things to do to our trucks (and I managed to screw it up) I forgot, I have one of those magnets on a stick ... duh, lol.
Old 08-20-2016, 06:03 PM   #4
midniteblues
midniteblues's Avatar
Since you kinda have the panels off now would be a good time too do a lil' extra work in there.
lube all the inner mechs.
sound deadner and vapor barrier.
I usually use the door panels as a rough templet and cut some heavy mill plastic and 2 face tape them too the door for moisture control.
I hear Peel and seal from lowes works good for sound deadner.
Grease and oil window rollers,regulator and inner door latches&lock assem.
A good flush of the inner bottoms and a coat of your fav. Rust control is allways a good idea too.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 08-20-2016, 06:26 PM   #5
CG
BlahBlahBlah
Yeah I considered doing the whole clean, lube, and insulate thing, but these doors are temporary. Rusted out along the bottom. The door panels were built with water proof board. So until (if) I ever get around to putting my better doors on Ill just live with them.
Old 08-20-2016, 09:58 PM   #6
57larry
let's see some pics of your new door panels please
57larry is offline   Reply With Quote
Old 08-20-2016, 10:02 PM   #7
CG
BlahBlahBlah
Ill see if I have better luck with the drivers side door tomorrow and post em up.
Old 08-20-2016, 11:31 PM   #8
FirstOwner69
FirstOwner69's Avatar
If all the screws supplied with the arm rests don't fit, could they be metric?
FirstOwner69 is offline   Reply With Quote
Old 08-21-2016, 10:50 AM   #9
midniteblues
I gotcha. Doors are allways a pita.
Sounds like the arm rests might be a lmc product since they know these trucks so well.
If you want too stay with screws through the panel license plate nuts should work well.
velcro sounds like a good idea also,been thinkin on doing this in my camaro those door panel clips are truly a pita.
Old 08-21-2016, 12:31 PM   #10
CG
BlahBlahBlah
I think Lowes have something like the license plate nuts. I really like the arm rests. Just a screw problem. They are Counterparts .. No idea if LMC uses the same ones.
Old 08-21-2016, 12:56 PM   #11
midniteblues
Ok i wouldnt use the plastic plate nuts for the arm rest though there can be too much stress on them at times.
Im sure thats what lmc would sell also. Im sure the rests are just fine.
Even though this isnt the correct item or size they make nut serts similar too these that should work for the rests and panels.
seems like you just need the correct size thread/screw/bolt for the rests though.
On my camaro arm rest/door pulls they use crappy screws over the yrs. The holes kept opening up till i had a huge screw too hold them in.
I reworked the inner door slightly too be able too use a j nut
like this. Only the ones i used had a longer "j" part.
Old 08-22-2016, 08:49 PM   #12
57larry
let's see some pics of the new door panels
Old 08-22-2016, 10:12 PM   #13
CG
BlahBlahBlah
Ill post up some pics soon as they are done. I didn't end up going back out to work on the other side yesterday. Just got home from work and am veg'ing in front of the TV watching the Mariner's VS Yankees.
Old 08-22-2016, 11:04 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I keep telling myself how much fun I'm having!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-22-2016, 11:30 PM   #15
snycal
********stupid question alert**********
What sound deadner are we refering too? Is it homemade or purchased and cut? Tia Lisa
snycal is offline   Reply With Quote
Old 08-23-2016, 12:35 AM   #16
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
The threads are wrong. Don't screw up your door nuts. On topic, I just received one of these today, and glad I did.
http://www.ebay.com/itm/291772516904...%3AMEBIDX%3AIT
One of these as well. Good bye tape measure:
http://www.ebay.com/itm/171977494280...%3AMEBIDX%3AIT
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-23-2016, 12:56 AM   #17
snycal
Thanks, I just bought the first one you linked. Helpful for sure...
Old 08-23-2016, 01:37 AM   #18
webfoot
I tried Velcro for holding up aftermarket door panels and it didn't work very well. It warped like crazy once it got kinda warm out and they sagged down a good bit. Ended up ditching all of it and using screws.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-23-2016, 06:16 AM   #19
cruisinthe34
cruisinthe34's Avatar
Your bolts are a different thread than the capture nuts. They SHOULD be 1/4 x 20 bolts
Steve
My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory
1971 C10 Inline 6 250 700R4 "Marlene"
1934 Chevrolet Master Sedan 350 700R4 "Iris"
1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose"
2019 Honda Ridgeline
cruisinthe34 is offline   Reply With Quote
Old 08-23-2016, 07:46 AM   #20
Things I find myself mumbling to myself at times...while working on vehcles:
"I volunteered for this sh*t??"
"I'm out here getting nowhere trying to get something done. Might as well have sat on the couch eatin' chips watchin' TV!"
"Hey, a new dance! One step forward and three steps back!"
Old 08-23-2016, 11:55 AM   #21
CG
BlahBlahBlah
On the 68's the door panel slips up under the chrome strip that is attached to the door, so that keeps everything along the top from moving or warping out.
Then the door handle and window crank keep it in place a little above the middle.
The arm rest / door pull is actually screwed in to the door which keep the door panel anchored solidly.
This Velcro has a ten pound rating, is wide and pretty thick heavy plastic. Not the cloth type you usually see. Time will tell on this stuff.
Old 08-23-2016, 01:46 PM   #22
jeffahart
jeffahart's Avatar
Here's a trick for getting small nuts and stuff out of places you can't reach your arm. Problem with telescopic magnets is they grab onto body parts.
Take a piece of screen, like window screen. Put it over the end of your shop vac hose. Then put your hose accessory/attachment on over the screen. You can vacuum up the part. When you turn off the vacuum the part will drop out of the hose attachment onto the floor. A good shop vac has a good amount of suction.
White K20
jeffahart is offline   Reply With Quote
Old 08-23-2016, 04:04 PM   #23
CG
BlahBlahBlah
A good idea that never occurred to me. We do have a pretty stout shop vac. Wonder what other stuff will come up from the bowels of the bottom of the door?
Old 08-23-2016, 06:59 PM   #24
GOPAPA
GOPAPA's Avatar
Never know until your magnitize or suck it out to see Mark,, I found a magnet at the bottom of my passenger door that was a old Farmers Insurance magnet and it proved that my truck came from lower California because AS it had a old phone number from that area and city
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 08-23-2016, 09:13 PM   #25
71CHEVYSHORTBED402
Great idea. I made an accessory for other uses that would work in the tight places. 5/8" OD hose on a more better Kirby accessory. If even smaller is needed, just insert a vacuum hose into the 5/8" hose.
Tony
