1969 C-20 396 Intake Casting Number
I have searched online to no avail for the intake manifold casting number that would have been on a 1969 C-20 396. All I have found so far are casting numbers for cars of similar vintage. Can someone point me in the right direction? Thanks!
GMC |
Re: 1969 C-20 396 Intake Casting Number
Only one casting that year. #3933163 ... a 396 intake is a 396 intake.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
That casting is not a truck Q-jet cast iron manifold
GMC |
My best guess is 3866961 for 66-69 396 truck.
That's the -only- number I can find that says 396 truck without being raised deck (366,427). https://www.rapidomarine.com/default..._castings.aspx
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
My 69 C/20 with a 350 came with a 68 drivers side exhaust manifold. So it is possible that you could have a older big block intake.
Casting numbers. http://outintheshop.com/faq/casting/castings2.html Last edited by Custom/20; 08-18-2016 at 07:20 PM. |
3883948 if your truck block is a 68 block and not a later 69 block
IT IS WHAT IT IS Last edited by jr1000yarder; 08-18-2016 at 10:23 PM. |
IT IS WHAT IT IS |
My 1969 C30 Longhorn 396 motor has 3931067. I was told it's stock and original, but it translates to 325 L-35.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
You have a picture of your carb springs on that set up?
IT IS WHAT IT IS |
![]() Posted via Mobile Device Posted via Mobile Device
![]() Join Date: Dec 2015
According to my book ("Car & Parts Catalog of Chevy V-8 Engine Casting Numbers 1955-93"), 3931067 is a '69 396 car and light truck cast iron oval port with Q-jet. I have found 3883948 to be '68 car and light truck cast iron oval port with Q-jet. Both of these are high rise intakes.
That sounds right Eagle
IT IS WHAT IT IS |
Ghalperin, what spring is on the front of the carb. I believe mine to be incorrect. ...
IT IS WHAT IT IS |
Thanks for the replies. I'll probably just get a 3931067 intake. For some reason I was thinking the truck intake was different for some reason.
GMC |
#15 | |
I can get you the number right off my factory 1970 unit, but that's newer than you want, I think.
#16 | |
#17 |
