Old 08-21-2016, 02:36 AM   #1
67-72lover
painting a chassis
what do you perfer to paint a chassis with? I've thinking about por 15 or chassis saver any feedback on either or something else better to use
67-72lover is offline   Reply With Quote
Old 08-21-2016, 06:36 AM   #2
tristan
Re: painting a chassis
POR-15, before and after.
tristan is offline   Reply With Quote
Old 08-21-2016, 07:50 AM   #3
GR8-68
GR8-68's Avatar
I prefer por 15 as well as that is always what I have used, holds up well and they have a great line of other products now as well.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 08-21-2016, 11:27 AM   #4
In The Ten Ring
What about epoxy priming? Sand blast, clean off sand, hit with epoxy primer?
*I don't know what kind, I am just thinking generally.
In The Ten Ring is offline   Reply With Quote
Old 08-21-2016, 11:36 AM   #5
67-72lover
looks very good. did you go threw the three step process as they say to do?
Old 08-21-2016, 11:37 AM   #6
67-72lover
did you use the three step process they say to use?
Old 08-21-2016, 11:42 AM   #7
dfosh
SPI black epoxy primer as close to stock color as you can get.
dfosh is offline   Reply With Quote
Old 08-21-2016, 11:43 AM   #8
B. W.
B. W.'s Avatar
X2 - I've done a few frames, I take them down to bare metal then use a 2-part epoxy primer, the last 2 frames I used PPG CRE which is an industrial primer that is chemical resistant. it is tintable. SPI (Southern Polyurethanes) has a frame paint that has what I think is the "proper" gloss but I haven't used it (probably will on the next one)
Many use POR 15 & it seams to work well, I have limited experience with it.
Bobby
B. W. is offline   Reply With Quote
Old 08-21-2016, 11:45 AM   #9
bL.A.zer90045
Now thats the ticket! I usually go this route,or blast and roughen up and hit them with chassis blackthe por is a "process" and in my expirience tends to "peel" off if one is "skipped"
bL.A.zer90045 is offline   Reply With Quote
Old 08-21-2016, 08:24 PM   #10
Eagle9502
I probably went a lot further than most people would but after sandblasting I went with SPI epoxy primer. Then a Nason 2K primer and cut out any rust pits. Then back over the whole frame with 400 before spraying with Summit chassis black. Turned out great and looks like a brand new frame.
Eagle9502 is offline   Reply With Quote
Old 08-21-2016, 08:29 PM   #11
projectking
projectking's Avatar
+1 for SPI epoxy!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 08-21-2016, 08:44 PM   #12
davepl
davepl's Avatar
I had everything black powder coated, pretty much. I threw in three shades of grey for various cast metal suspension pieces and so on. Can't beat powder, though it's not correct of course!
If you go the POR-15 route I'd recommend satin if you can get it. Much closer to the original "look" and it shows fewer defects, pits, and so on.
I have on car where they bodyworked the frame - skim coat of filler, etc, and it looks like a brand new, mint stamping. This frame was actually nice enough that I didn't need to do that, it barely had any rust at all.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-21-2016, 08:56 PM   #13
Metaldoc
Metaldoc's Avatar
Sand blasted, metal pickled, epoxy primer chassis saver satin black, and satin clear as chassis saver has no UV protection. This includes all under carriage and drive line parts.
Metaldoc is offline   Reply With Quote
Old 08-21-2016, 09:17 PM   #14
firedemon
how much does it take to do a longbed frame
firedemon is offline   Reply With Quote
Old 08-22-2016, 02:32 AM   #15
Metaldoc
Metaldoc's Avatar
I bought a gallon and it covered all my chassis parts plus.
Old 08-22-2016, 02:45 AM   #16
Blue/72
Blue/72's Avatar
I used por15 and then sprayed satin black over that, it looks great IMO and is fairly cheap. All in I was at about $60 in material
My dad always says that HEI distributers are pointless...
•1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money..
•1967 c10 with tach, dropped 3/5 on deep dish rally's
•1972 Cheyenne Super. Sold
Blue/72 is offline   Reply With Quote
Old 08-22-2016, 07:38 AM   #17
Cape Codder
Cape Codder's Avatar
I like POR 15 but would like to add from my experience that it will tend to peel from smooth sanded surfaces with time. It is made to stick to light rusted or sand blasted surfaces. This was straight from one of their reps. I spoke to at Carlisle years ago.
Cape Codder is offline   Reply With Quote
