Old 08-08-2016, 01:43 PM   #826
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
02
62stepside longbox is offline   Reply With Quote
Old 08-08-2016, 01:43 PM   #827
62stepside longbox
03
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
Old 08-08-2016, 03:22 PM   #828
66ChevyMax
66ChevyMax's Avatar
Engine looks great.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 08-08-2016, 05:48 PM   #829
All the little details are looking good together. Now you can scare the deer with your spotlight so you don't hit them.
Old 08-08-2016, 05:53 PM   #830
TJ's Chevy
TJ's Chevy's Avatar
I always say, "It don't matter what the truck looks like long as you have a perrty engine." lol Looks great man! And spot lights rock! I have been able to pick up 2 so far. One a GM and the other an S6 universal.
Old 08-09-2016, 01:48 AM   #831
62stepside longbox
Originally Posted by 66ChevyMax View Post
Engine looks great.
Thanks Craig, took a lot of work to get it this nice
Thanks bill, the details are what make the vehicle different. And yep now that whitetailed buck will see me coming from a mile away!
Thanks tj, your sure right about a Pertty engine! This spotlight is a unity s6 almost identical to the factory 60-63 spotlight, just a little earlier.
Old 08-10-2016, 03:03 AM   #832
62stepside longbox
Spent some time disassembling and polishing the spotlight and boy does she ever shine now! Chrome came out way better than I ever would've thought
Old 08-10-2016, 05:19 AM   #833
Very nice.
Old 08-10-2016, 06:22 AM   #834
Grizz1963
Grizz1963's Avatar
Originally Posted by 62stepside longbox View Post
And then I picked up this cool old spotlight from the late 40's that someone has already switched the bulb out to 12volt and it works great and Chrome is in pretty nice shape as well, best of all it only cost me $20
I have one as well.
Desperately want it on my truck but in two minds about cutting a hole in my cab.
Probably will fit it though.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 08-10-2016, 09:30 AM   #835
TJ's Chevy
TJ's Chevy's Avatar
Old 08-11-2016, 12:44 AM   #836
62stepside longbox
Very nice.
Thanks bill
Originally Posted by Grizz1963 View Post
I have one as well.
I say just go for it, holes can always be patched later down the road if need be.
Old 08-14-2016, 02:56 AM   #837
62stepside longbox
Well after contemplating about the motor mounts for a while an I decided after all to adapt the front mount to the new crossmember. So the first step was to take a bunch of measurements and then grind and drill out all the rivets to remove the perch from the crossmember, this was quite the chore but I finally got them all out. Next I will finish the last lower control arm so I can begin the crossmember swap.
Old 08-14-2016, 02:56 AM   #838
62stepside longbox
And the perch
Old 08-20-2016, 03:49 PM   #839
62stepside longbox
Engine is just about all buttoned up, I painted and reinstalled all the little odds and ends, she's looking good! Also ran some other lines
Old 08-20-2016, 04:07 PM   #840
66ChevyMax
66ChevyMax's Avatar
Can't wait to see that thing start up, great work.
Craig
Old 08-20-2016, 05:28 PM   #841
Old 08-20-2016, 10:24 PM   #842
62stepside longbox
Thanks, Neither can I
Old 08-21-2016, 10:40 AM   #843
AJCK87
Awesome job Nik! Your motor is looking great How's the motor mounts and front end coming?
AJCK87 is offline   Reply With Quote
Old 08-21-2016, 04:08 PM   #844
62stepside longbox
Thanks Anthony, in one of my past posts I mentioned that I decided to adapt the front mount to the new crossmember after all since it would be a lot less work than building side mounts from scratch. Now all I need to do is track down a rubber motor mount as mine has a large chunk missing and they are not reproduced. I'm actually in the kootney's right now and I have a couple leads on some
Old 08-22-2016, 12:33 AM   #845
TJ's Chevy
TJ's Chevy's Avatar
Looking great dude!
Old 08-22-2016, 09:37 PM   #846
64patina
Been a while since Ive been on here man, its came a long ways, looking good!
64patina is offline   Reply With Quote
Old 08-23-2016, 10:05 AM   #847
62stepside longbox
Looking great dude!
Thanks a lot guys!
Old 08-26-2016, 12:16 AM   #848
62stepside longbox
While on my ten day fishing trip I picked up this wilwood 3/4" clutch master cylinder, this is the same one that captainfab uses for his kit
Old 08-29-2016, 05:22 PM   #849
62stepside longbox
While passing through the middle of nowhere in northern B.C. I was able to track down and purchase a 60-62 v8 Bellhousing with the v8 horseshoe and other stuff for $75, this is just in case I ever decide to go with a v8 in the future, since these Bellhousings are hard to find and it was a good deal I couldn't pass it up. Oh and I have been searching while on the road but still haven't found a motor mount
Old 09-05-2016, 09:59 PM   #850
62stepside longbox
I've been pretty busy and lacking in updates recently but this weekend I decided to take advantage of the picknpull half priced sale. I got a set of springs from a half ton to cut down one coil ( my donor 78 had 3/4 ton springs), and a 8" brake booster from a s10, this is because my bigger booster from the 78 wouldn't fit in the engine bay with the oilbath aircleaner.
