Old 07-20-2016, 11:12 PM   #1
cjthompson
Dash lights
Anyone know a good supplier or have recommendations on what bulbs to use? Mine are pretty burnt out.
cjthompson is offline   Reply With Quote
Old 07-20-2016, 11:20 PM   #2
E.D.75GMC
E.D.75GMC's Avatar
Re: Dash lights
The bulbs are 194/168 any parts store will have them. If I were you though I would buy the 194 LEDs as they make a huge difference over stock and put less drain on the battery when you come to a stop.
E.D.75GMC is offline   Reply With Quote
Old 07-20-2016, 11:22 PM   #3
cjthompson
Re: Dash lights
Awesome! Do you happen to know quantities of each?
Old 07-20-2016, 11:36 PM   #4
chengny
chengny's Avatar
Re: Dash lights
You have 5 lamps for cluster backlighting and an other one - for HVAC control panel illumination - that is on the same circuit.
chengny is offline   Reply With Quote
Old 07-21-2016, 01:40 AM   #5
E.D.75GMC
E.D.75GMC's Avatar
Re: Dash lights
My 75 with no A/C used a different, smaller, bulb in the HVAC. Not sure what # it is though.
Old 07-21-2016, 01:41 AM   #6
E.D.75GMC
E.D.75GMC's Avatar
Re: Dash lights
Also, the LEDs are polarized so if some don't work just flip the bulb around 180 degrees.
Old 07-21-2016, 02:24 AM   #7
RUN GMC
RUN GMC's Avatar
Re: Dash lights
^this......after changing out each one turn on dash lights to see if led will light up....if not do what he said........
RUN GMC is offline   Reply With Quote
Old 07-21-2016, 11:57 AM   #8
TKCR
TKCR's Avatar
Re: Dash lights
I also used led bulbs when I replaced all the bulbs in the cluster. It lights up nice at night. Also added led's under the dash.
Old 08-22-2016, 03:22 PM   #9
LDO
LDO's Avatar
Re: Dash lights
Do you recall what PN led bulb goes under the dash? I believe the guage ones are 194s right?
LDO is offline   Reply With Quote
Old 08-22-2016, 03:37 PM   #10
TKCR
TKCR's Avatar
Re: Dash lights
1142 is the stock bulb. You can get LED's from any auto store. I added a set of courtesy lights from LMC. That gave me 3 lights under the dash.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=191
And yes, the 194 are the gauge bulbs.
Old 08-22-2016, 03:40 PM   #11
LDO
LDO's Avatar
Re: Dash lights
i purchased the same set of courtesy lights (harness) that comes with 2 bulbs. Was going to install LEDs in there to see how it looks.
Thanks!
Old 08-23-2016, 03:11 AM   #12
Danmcg
Re: Dash lights
Do the led's work with the dimmer switch?
Danmcg is offline   Reply With Quote
Old 08-23-2016, 09:58 AM   #13
CSHADES
CSHADES's Avatar
Re: Dash lights
Not without the correct dimmer for leds
CSHADES is offline   Reply With Quote
Old 08-24-2016, 03:53 PM   #14
TKCR
TKCR's Avatar
Re: Dash lights
Thanks!
The GM spec book calls for 1003 bulb, I looked it up to make sure this time. This is the led bulb I'm using
Old 08-24-2016, 03:55 PM   #15
TKCR
TKCR's Avatar
Re: Dash lights
Here's that spec sheet I was talking about for all the bulbs. Hope this helps for any bulb reference you might need.
Old 08-24-2016, 04:05 PM   #16
MikeB
MikeB's Avatar
Re: Dash lights
Just be careful of cheapie LED bulbs. I'd go with Philips or Sylvania/Osram, because they are brighter and last longer than eBay specials. If you shop around you can save some money on a 2-pack.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-24-2016, 04:23 PM   #17
TKCR
TKCR's Avatar
Re: Dash lights
Your right. I got mine in a 2 pack. I can't remember the brand name, but I have gotten several from superbrightleds.com. These particular bulbs I got from the local auto store, in a 2'pack.
Old 08-24-2016, 04:24 PM   #18
LDO
LDO's Avatar
Re: Dash lights
awesome,
thanks for that!!
Old 08-24-2016, 06:26 PM   #19
Marshy
Re: Dash lights
What does a pack of 2 cost anyways?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 08-25-2016, 10:50 AM   #20
TKCR
TKCR's Avatar
Re: Dash lights
Around $25
Old 08-25-2016, 11:17 AM   #21
Marshy
Re: Dash lights
Thanks.
Had anyone sourced a LED dimmer?
Vortec Engine Build
Old 08-25-2016, 09:44 PM   #22
NorCalAnthony
Re: Dash lights
Originally Posted by TKCR View Post
Around $25
Or $12.59 through Amazon with Prime shipping avaliable
https://www.amazon.com/gp/aw/d/B017V...ob_neva_mobile
NorCalAnthony is offline   Reply With Quote
Old 08-25-2016, 11:34 PM   #23
TKCR
TKCR's Avatar
Re: Dash lights
I was referring to the courtesy lights under the dash
Old 08-26-2016, 10:51 AM   #24
LDO
LDO's Avatar
Re: Dash lights
maybe a little off topic but how are you guys/gals getting lenses (the clear part) so clean?
I've seen some of your dash cluster pics and they look amazing!
Old 08-26-2016, 11:26 AM   #25
TKCR
TKCR's Avatar
Re: Dash lights
Myself, I got a new one. I added a clock to my cluster, so I had to get a new one. If you have a clock, the lens needs the little hole for the stem to come thru.
LMC has them. They are not to expensive, but so worth every penny, when you can actually see clearly.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=76
