Old 08-23-2016, 10:40 AM   #1
cpnbnanamn
Sonofa......!! CARB HELP!!!
So.. My truck's carb was starting hard and not running like it should.. And looking at the carb, it looked gummed up, so I decided to rebuild it. I tore it down, and dunked it in a carb cleaner, and am in the midst of rebuilding it, when I discover this... Hole. It's apparent SOMETHING was in there.. but I know for CERTAIN, I DIDN'T take anything out of it.. According to the exploded diagram I got with my carb kit, it's for the 'valve-idle vent (BV)' Yeah. I'm confused. I thought I had a 'B' carb?? Now, I'm not 100% sure WHICH carb I have!! The numbers that I found on the inside of the top-half of the carb are 7025523.. And I'm not sure if that matches to anything relevant!! (Edit: From what I'm reading, that's a casting number, and not relevant.)
HELP!!
1967 Chev C10 SWB Stepside with a L-6 250 CID engine, manual trans, manual choke.
cpnbnanamn is offline   Reply With Quote
Old 08-23-2016, 04:09 PM   #2
cpnbnanamn
Re: Sonofa......!! CARB HELP!!!
Does anyone have one of these laying around that might have the parts I need in it? I am hoping I don't have to go buy a new carb....
Old 08-23-2016, 04:20 PM   #3
Wrenchbender Ret
There is a valve that goes in there that looks like a slotted screw head. It opens when the throttle closes. I may have one but I won't get back to the shop till sat.
George
Wrenchbender Ret is offline   Reply With Quote
Old 08-23-2016, 04:36 PM   #4
cpnbnanamn
I appreciate you looking.. I'm not looking forward to having to buy a new carb just for a couple of lousy pieces!!
Old 08-23-2016, 04:52 PM   #5
Wrenchbender Ret
I'll look sat. That is a Model B Rochester. They have many variations through the years. Not all have that vent valve.
Old 08-27-2016, 05:06 PM   #6
Wrenchbender Ret
Well, I don't have one. I think you can put a plug in the hole with a small hole in it & it would be OK. I will send you a private message.
George
